Biostar TA790GXE AM3/AM2+/AM2 AMD 790GX Micro ATX AMD Motherboard Logo
Posted on Mar 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im having no signal to the monitor and a vga error on the mother board try everything
Khurram Shah
Level 3:
  • Master 10,322 Answers
  • Posted on Mar 15, 2010
Khurram Shah
Master
Level 3:
Answers
10322
Questions
0
Helped
1467618
Points
20232
It means there is problem in your VGA Card. VGA Card is Built in OR Insert in PCI Slot or AGP Slot Just change your Card
Problem will be solve . VGA Card Drivers
1helpful
LG monitor displays "D-SUB POWER SAVING MODE" when it is starting
The message it is displaying indicates that a VGA cable is connected and is not sending signal, or is sending a Monitor Off signal across the VGA cable. The motherboard battery will have no impact on this. If you are using something other than a VGA cable to send the signal to the monitor, then you should ensure that no VGA cable is plugged into the monitor, or the source on the monitor is not using the VGA connector.
Monitor does not come on
Hi Scott,
please check the removing the vga cable of monitor and turn its power on and display must show no signal error itself you can see it very clear text on it.
if your monitor good check the cable and plug it back to pc.then turn on the pc.if computer starts you can hear the HDD sound and please note the Beep sounds comes up or not ,if continues beep comes up problem can be with your pc memory modules or vga card ,sometimes mother board,
clean the ram card using smooth brush and mother board also.
unplug the power supply jack and re insert it .
remove the vga card also and do the same.
first all check the power unit fan is turning on when you press the power button too...
please let us know the results or come with more details.
regards.
nuwan
Upgraded power supply, upgraded to AMD 965 Quad core, Mother board stops at error C5, monitor blank during this. C5 error says reset video controller. HOW?
try this: 1. turn off the computer 2. disconnect the VGA connector (the cable from the monitor) 3. remove the video card from the motherboard 4. the motherboard has the on board video controller, connect your VGA monitor to that slot. 5. turn on the computer, I hope by now your monitor is ok ;-)
Monitor says no signal..even installed a board mount new graphics card, and tried other monitors
Remove the new graphics card and use the onboard VGA output from the mother board. Make sure the cable is mounted all the way in - sometimes the connection is loose.
Well i wanted to know whats wrong with my computer i dont know if im missing some cables but it says no signal.
It says no signal can be that the video card is not putting out video signal to the monitor, you need another monitor to verify that or you can try reseating the video card if it is not the integrated video card in the mother board. It can be the VGA cable itself. Try thsi monitor with other PC to make sure it is not the monitor problem.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sometimes No Video
Your Vga Driver is corruoted, if you have a Vga card separate reload the driver, if not reload the mother board driver. If the problem still appears, format the PC.
That is the best case. The other possibilty is mother board failure.
Good luck
No video signal on computer start up?
if u have built in VGA take off the Rams wash them with some ethanol then dry them with a blow drier then put them back into place and if u dant have built in VGA wash it as well
Does old mother board supports LCD monitor?
You’ll be fine.
Most LCD monitors either have VGA connection you’ll need or have VGA plus other connections but, all you need is the VGA connection.
2answers
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Is it my monitor or my video card
1.there might be a problem with your signal cable. if one of the pin in the signal cable is open. it might also happens
2.adjust signal cable.
3.Check VGA video card is working properly. unplug the VGA card and Re-plug to its slot. if your mother borad has inbuilt video card. this process cannot be performed
4.Even problem with operating system might also happen.. problem with Video Ram memory
5.if you want to check whether your monitor is ok. just get Cpu Box alone frm friends for a while for a testing.
6. if your monitor have problem then contact service centre.
Top Biostar Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
