Sears Kenmore Elite Electric Dryer Model #110.60932990. Replaced the heat element and the Thermal Cut-Off aand thermostat. Cleaned inside and out for Lint Build-up incluing front lint trap housing and rea exhaust. All this still no heat.
Unit runs on 210-220 circuit breaker, not the problem.
Where to go from here. Spent $100.00 on parts, still no satisfaction!
Sears Kenmore Elite Electric Dryer Modle # 110. 60932990. When running I can see the heating elements are on. Around 10 mins later the dryer cuts off.
You may need to do some troubleshooting. This can be done with the machine unplugged - you may have to activate the start switch, belt switch (if it has one) and the motor centrifugal switch manually.
Tip for troubleshooting 220v systems - clip one lead of a ohm meter to either L1 or L2 on the terminal block. It doesn't matter which one. According to the tech sheet (under console) follow the path for current from your clipped terminal, through the heating element, to the opposite terminal. All the readings should be less than 100 ohms, until you reach the failed part. Confirm failure by disconnecting a lead from the suspected part, and test only that part.
Live troubleshooting is sometimes slightly easier, but much more dangerous than the procedure described above. - It is definitely not recommended for beginners, or for professionals, if it can be avoided.
My Kenmore Elite HE3 dryer also does not heat, but still tumbles. It was purchased brand new 6 years ago. What do you suggest? I hate to buy a new one, and I don't want to go through all the effort the other poster did, just to have it not work for me as well. Thank you.
Our Kenmore Elite HE3 model# 110.82822101 runs.. but there is no heat. How do we fix this?
My kenmore dryer is only 4 years old and also has no heat. I spent a good amount of money of this dryer and it has been nothing but a problem. Had it "serviced" 4 times by Sears and now I think my solution to this latest problem is the curb! I will not buy another Kenmore brand appliance again!
