Question about Miele Novotronic W1918A Front Load Washer
Inlet water red trouble flashing cycle stops
All is fine up to the start of the first rinse cycle. During the first rinse cycle the water is only comming from one of the three cold water inlet soleniods which provides insufficent water supply to the drum, I think the level control valve sences the lack of sufficent water and signals the machine to stop. Howerver the machine does not always stop dispite the low level of water and the trouble light still flashing. The cycles continues to the second rinse cycle at which point all three inlet soleniods work providing sufficent water to the drum. Because the inlet water vavles works during the second rinse cycle I think they can be ruled out as the problem, I am thinking it is the circuit board. What do you think?
5 Suggested Answers
Lumpy816
  • 246 Answers
SOURCE: replace inlet vavle
Gupshaw, I know this is a duplicate, so I'm just trying to get this ticket closed out. However, if you check this one first, here's all the information too.
Unfortuneately the 24032\24036 is a series number that encorporates many models numbers of machines. These instructions will therefore try and cover all of the models in this series. Thankfully, most of the steps are all similar for the whole series.
To help get you machine going again faster, have you already purchased a replacment water valve? While you can order them online from the manufacturer, it is far easier and quicker to take the same model number to a local appliance parts store (usually listed in the phone book) and just get one from them (typically it is cheaper this way too). Now that you have your part, these are the basic's.
First, you have to un plug the unit. Next turn the hot and cold water valves coming from your house off. Next, loosen the hose connectors where they meet the machine using plier or channel locks. There will be water left in them so if don't want the small amount of water on the floor, I recommend holing a wash cloth, towel, rag, etc underneath them. Once they are disconnected, lay them out of the way, or tie them to the large black drain hose. There will be 1 or 2 (depending on your model) 1/4 inch screws that hold the valve on next to where you removed the hoses. Go ahead and take these out now too.
Now to get inside, open the console. There are 3 common ways to open them for this series. The most common is models have plastic caps covering the 2 phillips screws that will be on the right and left hand sides where the console meets the top of the washer. Just firmly pull on the right and left corners at the top to remove the covers and the screws underneath. The next most sommon style is 2 phillips screws on the back side of the console where it meets the top of the washer. This style will have no covers. The 3rd most common type is when there are no screws or caps. This last style, you will have to use a putty knife or narrow flat head screw driver. Insert it under the front right and left hand sides where the console meets the top in the front. Push it in between the top and console and it will release the clip. All 3 styles will now rotate up and towards the rear of the machine. It's the same from here on in for all of the series. Underneath the console there will be 3 wires connected to the top of the washer. (genreally a combanation of brown, green, whit, or gray) Unplug this connector by gently prying the clip on the side of the connector and gently pulling). Next, remove the 2 brass colored clips underneath by pushing down with a large screwdriver at the point where it goes into the top of the machine while simultaniously pushing towards the rear. Once these clips are off, it will let the top, front and both sides come off as one assembly. First tilt the top towards you (about 45 degrees). Now put one hand inside under the lid to pick up on the cabinet while keeping the other hand on the back of the cabinet to keep the whole cabinet tilted. Once you set the cabinet aside, locate your water valve on the inside of the machine. You will find 2-4 connectors going to the valve depending on the model. Just jot down what order they are in then remove them. Again gently pry the locking tab to the side and slide the connector off. Finnally, you will see a black rubber hose with a silver or green clamp on the bottom of the valve. Just squeeze the clamp together, and pull the hose off (watch out for that left over water again). Now you just re-assemble everything in reverse order.
I always recommend you test your washer (fill it, agitate it and spin it out) while you are standing there to make sure you didn't miss one of these steps and have some unpleasent leaks.
If you are still having problems or run into trouble, send me back your specific model number (If you lift the lid to your washer and look at the plaque on the back center just under the lid you will have a model number [usually started with a 110.]) and where you got hung up at and we'll get you on through it.
Finnally, if this has taken care of everthing you needed, please don't forget to log back in and score my information. It helps others find me so I can assist them as well.
Posted on Jul 18, 2008
tzweeb
  • 318 Answers
SOURCE: how to replace inlet vavle
yes your inlet water valve is the problem. you have to remove the outer cabinet first by taking the control panel loose and "flipping it back, then remove the 2 hold down clips, kindof a wierd "s" shaped thing in each upper corner, then the cabinet will "hinge" forward allowing you to get into where the valve is at. the rest should be easy, a single mounting screw and the 2 hoses, make sure to put the wiring plugs back on in the correct place on the new valve.
Posted on Dec 28, 2008
jumptrout51
  • 3361 Answers
SOURCE: i'm replacing the cold inlet vavle on a wd420g
Copy and paste this link for your manual.
http://appliancejunk.com/ge/washer/31-9135.pdf
Posted on Jan 04, 2010
SOURCE: I have a Miele W1918 washer which has worked
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Posted on Nov 28, 2010
Washer stops during rinse cycle and beeps at me
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Oct 02, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Wd440 not spinning and flashing lights
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jun 27, 2012 | Hotpoint Washing Machines
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Washer has been working fine for sevral years.I started a load when it went into rinse cycle it stopped and will not run at all. this is a Kenmore extra large capacity model no. 110.14102300
If no water entered the machine at the rinse cycle, then I would check for a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are clear of rust or debris. Pay particular attention to the cold water side. Next, check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad solenoid. I will attach a photo for reference. Check this and if you need additional assistance let me know. I am working with limited info. For instance, can you advance the cycle manually and make the machine operate? Sorry for your trouble and I hope this helped. Best wishes.
Sep 02, 2009 | Kenmore 22422 Top Load Washer
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rinse Cycle Doesn't Fill with Water
You may want to double check you have the inlet hoses around the correct way as if you have the cold hose going to the hot valve it would cause this fault. If the machine doesnt spin properly also it could be a faulty Out of balance switch. cheers.
Apr 03, 2009 | Fisher and Paykel GWL11 Top Load Washer
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
Miele Novotronic W 844 Washing Machine
Pete,
When I had this problem I went along the entire water inlet route and verified flow. Water flow entering the soap dispenser tray should be very robust & audible; if not, you have a flow restriction or low pressure, flashing red light or not.
I'm stating the obvious because I actually missed some filter elements the first time I tried. Disconnect inlet hose at plastic fitting on chassis and verify your flow there. Then look inside the inlet barb and use a small pair of channel lock or lineman's pliers to grasp the tab on the inverted "basket" and pull it straight out. These filters can be packed full of sand and small gravel inside--they were in my case.
Good luck,
Adam
Aug 03, 2008 | Miele Novotronic W1918A Front Load Washer
Miele Novotronic W1918A Front Load Washer Logo
53 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
