Usb 2 can i upgrade my mx4bs motherboard to use usb2 devices without working at lower speed
    President:
  • 2,351 Answers
Hi truckereric, The short answer no.
USB 2.0 is acheaved by two things.
1. You need to enter your system boards Bios. Find the USB settings. If USB 2.0 is listed here than your board will support it.
2. USB 2.0 is installed through windows updates.
3. If your board can't handle USB 2.0 maybe there is a Bios update. No, I checked your bios & there is no bios update to bring you up to USB 2.0.
AOpen's driver / software & bios support found at the link posted here. http://download.aopen.com.tw/Default.aspx
You'll need to fill in the three dropdown menues.
Motherboard
MX4BS
& Order by: LastUpdated
There are five pages of updates. If you change the Category dropdown menue to Bios. AOpen will show you the bios updates.
At least you have AOpends update link.
You can always add a PCI card that supports USB 2.0
http://www.buyextras.com/synecchusb20.html?gclid=CP_cvvGF_pECFQuAHgod0mYK4w
Best regards.
Posted on Mar 08, 2008
This divise can perform faster if u can connect it to a high-speed usb devise! And what is a usb2 devise
USB = Universal Serial Bus and when it first entered the market the maximum speed was 1,5Mbit/s (this was called USB 1.0).
After a while they upgraded to usb 1.1 (12Mbit/s) and then to USB 2.0 (480Mbit/s). This is where we are now. Your computer is able to handle USB2.0, however if you have an old printer or something else, which was designed when the standard was USB 1.0, the maximum speed for that device is 1,5Mbit/s.
If you plug a newer device into a "slow" usb port (for example your usb port =1.0 and device supports usb 2.0) , then you will get information saying : "this device can perform faster...."
expect usb3.0 soon with 4,8Gbit/s
Dec 22, 2009 | ASUS P5LD2-VM Motherboard
When i plug in my memorycard adapter into the usb ports .the baloon says i need a hispeed usb host controller.
The memory card you have is for a USB2 configuration and the USB port configuration or port you are using is USB1 configuration.
Try a different port or check the manual for port layout or description.
Sep 26, 2009 | DFI WB72-SC Motherboard
The system comments that this is not a usb 2 device
first thing is that message just means that your device will work at a reduced speed
second is that a high speed port or enhanced usb port is required to work it at enhanced speeds
to check if your usb port is enhanced goto : control panel / system properties / hardware tab / device mannager / then scroll down to usb controllers and see if it says enhanced next to your usb port if it does then you will need to get the updated usb driver for the enhanced speed
electech
Nov 23, 2008 | VIA Vectro VT6212 (A62124) Serial Adapter
USB Port won't recognize plug n Play devices
do you have the upgrade for your O/S to recognize usb 2 as sometimes when first plugged in a usb device my computer has come up with your usb is 1.1 you need to upgrade to sp2 or whatever to have usb2
Aug 11, 2008 | EliteGroup K7S5A Pro Motherboard
No hi speed usb2
Hi there, Any PCI - USB2 card will be suitable for your motherboard.
Feb 25, 2008 | AOpen AX45-V (91.88I10.004) Motherboard
Usb 2.0
this is a common error with operating systems and devices.
If you go into my Computer/system/device manager. And remove the installed USB devices. shutdown the computer, and reboot it. then try putting your USB device in.
What general happens, is that if you have had an older device in the USB port at any time, the port configures itself to this setting. options are to try another port on the computer ( some older ports only support usb1.1 )
ensure you have up to date drivers on the connecting device and on the connecting computer.
Hope this helps Mike @ Compurepair.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
USB2 high speed not recognize
Try opening up the device manager and unistall everything in the Universal Serial Bus Controllers. Then reboot and let windows reinstall the USB controllers. Windows should now be able to recognize properly USB2 devices.
Usb
What speed is the USB port on your laptop? Is it 2.0? or 1.0?
Sep 12, 2007 | Computers & Internet
Asus T2-P
Try re installing the usb2 drivers from the motherboard drivers. Although they will not show up as as usb 2 in the device properties, use sisoft sandra (free download), as this will show them as high speed or usb2.
Jan 28, 2007 | ASUS (t2psimpledlx) Barebone
It sounds like your Windows XP might be missing the USB2 drivers. Try going here http://www.windowsmarketplace.com/ and download the driver needed and see if that fixes your issue.
Sep 27, 2006 | ASUS P5LD2-VM Motherboard
Computers & Internet Logo
175 people viewed this question
David Payne
David Payne
