Question about Toshiba Satellite A135-S4467 Notebook
Will not boot up
My computer told me to restart after I loaded a program, and when I did, it would not sayed there was an error and the system could not start. I tried all the recovery options but none work. I have many important files that I would hate to lose.
  • 520 Answers
Firstly try press f 8 at start and enter start with last known good config.you may of tried this ...unsure.
if no joy make sure you have system disk in cd drive(windows disk)start up..if pc say click any key to start from cd do it.if it dont need to enable boot from cd first in bios options.
when boot from cd system ask install os or repair ...choose install.system checks for existing os and informs you of this.ask if want install new or repair ...at this point you can select repair.cd will start instalation and no previously installed programs will be lost..
Posted on Mar 08, 2008
When i start my computer it come on but i have hit the f1key to start my computer
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system.
Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd.
hope this helps
Nov 18, 2012 | Dell Dimension 9200 PC Desktop
Why does my computer get stuck on the Windows XP restart window that says
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps
Aug 14, 2012 | Dell Latitude E6500 Laptop
Dell inspiron 5315 when trying to boot up it say power save how to fix
hope this helps
Jun 15, 2012 | Dell Inspiron 531s Desktop Computer
My acer aspire one zg5 got the blue screen. after loading the windows, it will stop then flash the blue screen then restart again and again. what will i do? somebody say my netbook needs to reformat. but i...
Follow these steps to fix a Blue Screen in Safe Mode
Once booting start, select "Safe Mode" from the boot menu.
Scan your hard drive by running your antivirus software . If the program locates an infection, move it to your vault or follow the on-screen instructions. After program completion, if a virus was removed, attempt to reboot your computer and see if this clears up the problem. If not, restart your computer in safe mode.
Restore your computer to a previous point. Click on the "Start" button. Select "All Programs", "Accessories", "System Tools" and finally "System Restore". Choose a restore point on or before the last day your computer worked without error. Finally Reboot your computer to see if it loads correctly.
Mar 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have dell inspiron laptop, suddenly a problem occured I quot that :windows faild to start a recent software or hardware change might be the cause to fix the problem : 1-insert your windows...
Shut your computer all the way down. As soon as you turn it on, start hitting F8 about 3-4 times, that will take you to an advanced options menu. Select "Last known good configuration" and that should work
Mar 08, 2011 | Computers & Internet
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
Error loading operating system
1. The reason it says "error loading operating system" is because kill disk wiped the operating system from off your computer.
2. Now that you have the installation disk, you need to tell the computer to boot from it. For Dells, usually press F12 when the Dell logo appears, and it should bring up a boot menu. Select the optical drive and it should boot. If you do not see a boot menu, go into your computer's BIOS and tell it to look at the optical drive first when booting, then it will boot from the disk.
Jun 28, 2009 | Dell Inspiron 1100 Notebook
Cant get windows xp to load
Hit F8 while it is booting up and take it into SAFE MODE if at all possible. From there run an error check.
Go to My Computer - right click on C: -- go to properties - then select Tools - error check. Make sure you check the two boxes to have windoews fix the errors as they are found. The error check should run after you restart your computer.
if it still doesn't load.. reboot while presssing F8 and take it into safe mode and use SYSTEM RESTORE to restore computer to earlier date.
Go to:
START - ACCESSORIES - SYSTEM TOOLS -- SYSTEM RESTORE. and then select a date computer was working ok.
May 27, 2009 | Compaq Evo N600c Notebook
CD BOOT: MEMORY OVERFLOW ERROR
did you overclock you cmos? go to cmos again and load factory default. and try to install xp again.
Feb 16, 2009 | Microsoft Windows XP Professional
When I turn on my computer it loads and works for 2 mins and then a blank screen comes up and says software installation An unrecoverable error has occured. The installation program cannot...
try to repair your system using your cd operating system, but get note prepare all your device driver,
1. go to cmos setup then select the first boot to cdrom
2. put the operating system cd into cdrom
3 restart by pressing ctrl-alt-del after restart.
4.press any key boot from cd.
5.follow instruction
hope it will help thanks, pm me if theres a question.
May 25, 2008 | HP Computers & Internet
Toshiba Satellite A135-S4467 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
