Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon D 80 with 18 130mm lens
My Camera seems like work ,beeb sounded only once ,than since does not any more . No matter how many times ,ways I do reset ?
Any one has idea ?
Michael
  • misi Mar 09, 2008
    Hello Canada Bruce !
    Thanks ! I done that ,and also done Master Reset , it just do not beeb . Otherwise work ,and focusing very good .
    mis
  • 58 Answers
Under the "Custom Settings Menu."   You can turn the beep on and off."
Posted on Mar 09, 2008
  • Bruce  Scott
    Bruce Scott Mar 09, 2008
    To tell you the truth, Misi, I find the beep very annoying, and I have mine turned off all the time.   But, to each his or her own, right?
Will resetting my camera make the buttons work again? Is there a way to reset the camera without going to the menu (since the buttons don't work)?
Only the two buttons on top of the camera. It looks like you have a real problem. All buttons on the back look dead.
Reset of a camera is done every time you switch it on, so that will not bring any difference. One step up is removing the battery for a few moments, bit when the error keeps coming back, I think someone must have dropped the camera once, or some moisture came in the camera, and did something with internal connections.
When nothing helps and you did not drop the camera, check if it is still under warranty and contact a Olympus certified service centre.
DOn't send it in unless you know what it could cost. Sometimes repairs are more expensive than a new camera.
Jan 28, 2015 | Olympus Vr-340 16mp Camera Digital Optical...
My camera does not seem to take a charge
Is it a camera or your cell phone? Either way, it sounds as though the battery is shot and will need to be replaced. it's hard to help you much past this without knowing the model. Sometimes, if you can get the power on enough to do a factory reset from the menu that helps with a charging issue.
Dec 24, 2014 | Cameras
After filling, stops, lights up cold temp and beebs
are you using the pre soak cycle ? if so it wil start up after the soak time cycle is up.otherwise skip this function.
Jul 03, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Intel desktop board D845wN - no screen display
HI,
Switch on your computer and listen for a beeb sound.... if no beeb sound available then your Motherboard has a problem.
if beeb sound comes then switch off your computer and see for the loose contacts on motherboard.
eg. remove ram, clean ram socket and put back the ram
your problem may solved.
thanks
ehsan (md_ehsan_1@yahoo.co.in)
Jun 15, 2009 | Intel Desktop Board D845WN Motherboard
No dial tone or just static or 2 beebs
I HAVE THE EXACT SAME PROBLEM. I'M ALSO LOOKING FOR A SOLUTION.
WHEN MINE DOES THAT I UNPLUG THE ADAPTER FROM THE WALL FOR A COUPLE SECONDS THEN PLUG IT IN . IT'S VERY ANNOYING. IF I FIND THE SOLUTION, I'LL LET YOU KNOW. IF YOU GET A SOLUTION, MAYBE
YOU CAN LET ME KNOW.
toom45@verizon.net
Jun 09, 2009 | Uniden Cordless Phone
FIC FR33E long beeb ?
Take out your memory modules and reseat them. One of them may not be in all the way.
AWARD BIOS BEEP CODE ERROR - 1 Long Beep - Memory Problem (Module not seated well)
May 15, 2008 | FIC FR33E Motherboard
Often doesn't open ok.
could be lens or could be the batteries not strong enough.. try using those new lithium batteries designed for digital cameras
Oct 24, 2007 | Olympus SP-550 UZ Digital Camera
Red pictures with lines
Seems to be a board fault - time for the next camera.
May 17, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Camera Won't Turn On
have you tried plugging it to the wall AC? Use a reset button if there is one. Leave the camera with batteries out for a day or two. If nothing seems to have an effect take it to a repair shop to get a repair estimate, see if it's worth it. Good luck!
Jun 03, 2006 | Samsung Digimax 301 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
168 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
