Most likely problem is a loose or bad open switch on the passenger door. See if you can spot the switch and check to see if it's loose. Problem could also be that the door latch needs to be adjusted to close more tightly.
You will need to have your Check Engine Light code scanned with an OBDII scanner. Autozone and Advance Auto Parts will both scan your vehicle for free and tell you the codes. Let me know the codes when you find out what they are.
Hello Friend,
This is automatically adjusting your Screen.Horizontal/vertical manual manual adjustment and Focus adjustment can Solve the Problem.Turn off auto feature.
I hope your Problem can be Solved by going to this link for Detailed Instruction of your Monitor...
Thanks for Contacting FixYa...Keep Using..
Is this your monitor menu screen that keep on poping up. the monitor or the screen is not set properly. unlpug the monitor wait 10 seconds and replug back in. if you have video driver install it. 95% this will solve your problem. If you have samsung lcd flat screen press auto button.
Dear Frac1969,
There are many reasons when flash isn't poping up. Flash selection could be OFF from menu or its setting is Auto. Are you geting any error message in camera when you try to use Flash function?
