Question about Sony DVP-NC85H Multi-disc DVD Player
Locked dvd tray.
The open/close button will not open the dvd tray and a "locked" message appears in the window. tray is locked. tried to unlock it per the users manual, but it does not work!
  • 4 more comments
  • beth_s Mar 29, 2008
    I have the same problem. Tried return, enter, power like the manual said, tried unplugging it and power, stop, eject at the same time. Nothing works. I never locked this in the first place. Sony used to make the best electronics but everything I have purchased in the last few years is junk.
  • Jesse Garza Jul 27, 2008
    I have the same problem. Locked on screen. Called Sony. Only solution is send it in.
  • Anonymous Oct 25, 2008
    tray locked same problem same unit
  • Anonymous Nov 30, 2008
    "LOCKED" is displayed when I try to open the DVD player. I had a library DVD in the tray at the time, so I had to force the tray open to get it out.
    Called Sony and Best Buy but since I'd had it for a year or so, they would do nothing for me. Very irritating. I thought buying a Sony would mean reliability.
  • Anonymous Feb 13, 2009
    My unit did the same thing and I read all the answers to every question. The plain fact is that if you turn it on and it says locked and you did not do it and you tried all the remedys then send it in like I did and get another or. Stop prying these units open to get you discs out. Carefully lean the unit to one side to prevent the discs from falling out of the tray. Locate a small hole in the bottom of the unit and insert a flat head scredriver until you feel the slot. Rotate the screwdriver either way until the tray starts to open. Mine had a flat blade opening yours could be a phillips. If you have already opened the unit, turn in over get a flashlight and look through the hole and you will see what I mean.
    JC
  • smb8 Mar 22, 2009
    same problem
    tray "LOCKED" did not lok it in the first place. Tried all suggestions without success
  • 10,594 Answers
Press stop and eject buttons on player for 6 seconds, display will show unlock message and job is done.
Posted on Nov 06, 2008
The proble is show me "TRAY LOCKED" IN MY DVD RDR HX520 DVD SONY. I TRIED 6 MINUTES WITH PRESS STOP AND EJECT TOGETHER WITH NO RESULT. PLEASE HELP ME!!!
Posted on Feb 13, 2009
This worked for me:
Don't bother with the tech support line. Take a philips screwdriver and remove the 2 large screws on the sides of the unit, then the 3 screws in back that attach the shell to the main body of the unit. Slide the shell back. You can now access the DVDs that your Sony player has kidnapped.
This is totally ghetto, but you CAN change discs now. I bought the unit for $99, and tech support wanted me to ship the unit on my own dime, plus pay $99 for a refurbished unit, PLUS shipping back to me. This was their best solution. :|
You can try unplugging the wires/cables inside and then re-inserting them, but it didn't work for me. I recommend turning the power off first.
I will probably use the changer this way for a while, but I'll be looking for a new unit to replace it with.
I really thought I was safe buying this big name brand, and the unit served me well for 2 years... Next time I'll do more research first, because this seems like a common issue.
Posted on Jan 17, 2009
My kids locked my rca dvd player model rc5220p
The Disc Tray is Locked
If the message “Tray Locked” appears on the screen, the retail lock feature has
been accidentally engaged. To unlock the disc tray you must press and hold a
combination of keys simultaneously:
On the front panel of the DVD Player, press and hold the STOP, ON•OFF and
OPEN•CLOSE buttons for at least 3 seconds.
I forget the password Your player is equipped with a “back-door” unlock sequence. Press and hold
the STOP button on the front of the DVD Player and the STOP button on the
remote control at the same time. (Hold both buttons down at the same time
for at least 3 seconds).
Dec 28, 2008 | Televison & Video
Locked dvd tray.
have you tried to unplug the unit from the mains power wait around a minute and power back on if not press the setup button on the remote and reset to factory defaults.
Thanks J
Feb 16, 2008 | Televison & Video
Locked dvd tray.
Press Setup then the numbers 2 0 0 5 then setup and it should unlock
or
Display 2 0 0 5 Display
Dec 22, 2008 | Toshiba SD-K760 DVD Player
Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
Jul 08, 2008 | JVC TH-S11 Theater System
DVD-RAM will not eject via "OPEN" tray command
Hey I just found out how to UNLOCK the tray
Power up the unit, wait for it to read the disc if one is inserted.
hold the stop button and the power button down together for 5 seconds
the display will show UNLOCKED
Open/close button should be restored
Apr 03, 2008 | Panasonic DMR-T2020 DVD Recorder
DVD Tray is locked
Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
Jan 18, 2008 | Sanyo DWM-390 DVD Player
Locked dvd tray.
Hi SoraTotoro,
This sounds like the child lock has been inadvertently activated . Look through the manual to find the key combination to unlock it.
Hope this helps.
Spare head 2.
Jan 06, 2008 | Televison & Video
Locked dvd tray.
Press and Hold EJECT Button, While UNLOCK Is Displayed :-)
Nov 12, 2007 | Sanyo DVD-7201 DVD Player
Locked dvd tray.
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears.   The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
Apr 07, 2006 | Panasonic DVD-A110 DVD Player
Sony DVP-NC85H Multi-disc DVD Player Logo
999 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
