Brothe MFC-240C paper jam error msg won't clear
MFC-240C printer had paper jam; I cleared it; still get error msg, remove back cover, paper jam. I deleted printer and reinstalled from disc. Can't print or clear msg.
**, it is not fixed. I followed instructions on Brother web site and was able to find a piece of paper near the printhead, so I removed it. The printer makes a grinding sound when it tries to print and the same paper jam error returns and can't be cleared. I beleive that the printer repair cost will be more expensive than replacing it with a different printer, and it won't be Brother brand. I probably would not be able or have the tools to do any complicated repair job.
Posted on Mar 09, 2008
My display screen on my Brother MFC-240C says "Paper Jam" and there is no jam. How do I reset it?
You press Menu/Set 2,0,3, then press up/down arrows set faxibility to on. Press menu/Set, then press up/down arrows to turn call waiting on or off. Press Menu/Set and lastly press Exit/Stop.
Sep 12, 2012 | Brother Multi-Function Center MFC-240C...
I cannot print or copy . i see error 51
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
May 16, 2010 | Brother Multi-Function Center MFC-240C...
Brother printer mfc 240 error 50?
this error is due to the machine does not work due to a paper jam.Clear the paper jam or may some mechanism not functioning properly check it ....
Dec 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
My Brother MFC-240C is insisting I have a paper jam. I removed the paper but it won't reset. Is there a way to reset this?
After you look inside on the right and left sides where the carriage travels for any paper scraps, you can unplug and plug back in while you hold the stop button and it might clear the error.
Nov 05, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer papper jam cant see any papper mfc-240c
Did you remove the rear cover and check for paper there? If it still shows a jam and there's absolutely no paper inside the printer, you may have to shut it off (or unplug it if it won't turn off), wait a few seconds, and turn it back on to clear the jam detection.
Sep 05, 2009 | Brother MFC 240C All-In-One InkJet Printer
Error 50 after jammed paper on brother MFC-240c
I had this too, I had to open the back of the machine, it is meant to open and pull out and clear the jam (pull out the crinkled paper) but everytime I tried to print again it kept saying that it still had the jam, I opened and closed it several times and it did not seem to register that I HAD CLEARED THE JAM, so what I did was unplug it from the wall and then plug it back in and then it was fine. I wonder if this is AN ACTUAL DEFECT with this machine, if ater a paper jam it cannot detect that it has been resolved without having to unplug it and plug it back in, HOPE THIS WORKS FOR YOU.
Feb 24, 2009 | Brother Multi-Function Center MFC-240C...
My Brother Multi-Function Center MFC-240C All-in-0ne Paper Jammed
how i can i plug mymulti-function center mfc model mfc240c to my pc
Dec 08, 2008 | Brother Multi-Function Center MFC-240C...
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
