Question about Philips DIRECTV H20 DTV Receiver
Directv h20 receiver has low volyage to the lnb.
Voltage at sat in connector is 7.5 volts, but with lnb connected voltage drops to less than one volt. Is there a dropping resistor in that circuit or what may the problem be. no shorts in rf cable. it is ok
  • Tom Herschlein
    Tom Herschlein Mar 08, 2008
    jaime, where can I download a schematic for H20 Receiver
  • 2,336 Answers
Check inside the receiver for a defective LM317 IC or a TIP42C transistor, but before that you should check for proper voltage from the power supply to that IC.
LM317/TIP42C control the switching of voltages that power up the LNB, you should be getting 14 volts for vertical channels and 18 volts for horizontal.
Good Luck.
Posted on Mar 08, 2008
No voltaje in conector
Posted on Sep 03, 2009
My1997sporster batt full charge conections tight, turn key on lights come on push starter button and nothing,pulled batt back out to check lines, batt sat in holder, tryed to start . It started and ran ,...
Have u checked the starter connection? Sounds like ur starter solenoid is malfunctioning, the starter relay and the starter switch.
Clean the battery terminal and the connector thoroughly.
Try to short the positive terminal connection of the solenoid and tell us wut happened.
Jun 12, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Jeep totally lost power. Don't think battery went bad that fast. Jeep has no power what's-so-ever
Begin by checking voltage (with a volt meter) at the battery terminals (part of the battery not the connectors). Voltage should read somewhere around 12volts (a volt above or slightly less is OK, but not lower than 11.9) Then move the positive probe to the connector and check, again, move the negative probe to the connector. Leave the probe at the positive terminal and check voltage between the block and the battery by touching the negative probe to any metal part of the block. Continue working your way down the harness on the positive side, checking volts at the power distribution center, fuses and at the main battery connection on the starter. As you get further from the battery the voltage will be slighty less but you should not see a radical drop. If you find a large drop or no volts at all where you'd expect to have a reading, stop there and find the cause.
Chances are the connections on the battery are bad and you won't have to look further than that.
If battery is not at the proper voltage, re charge it and then put the meter on both terminals and check running voltage. It should be at least 12.9 to 14 volts running and should not drop below 12.5 with all accessories on including the lights. If it does, check the alternator and drive belt.
Oct 16, 2010 | 2000 Jeep Grand Cherokee
Brand new battery and still cant get it started???
Read the voltage at the starter terminal that goes back to the battery (connect the other meter lead to unpainted engine metal). It should read 12.6 volts even when you attempt start. If it reads less voltage, or the voltage drops to zero when start is attempted, look carefully at the positive battery connector and wire for white/green corrosion. Check the negative terminal wiring too, but corrosion is not as likely. If the battery itself does not read 12.6 volts, the new battery may require charging at low current for about 6 hours. Hope this helps!
Jun 06, 2010 | 2001 Suzuki GSX 750 F (Katana)
My 1997 jeep grand cherokee tsi with a 5.2 seems to have a charging problem. the alternator is a year old and was tested twice in the last week at 2 different locations and was shown to be good. same thing...
How is the pigtail ground strap from engine block to body? Have you had engine diagnostic test done? Voltage rVOLTAGE DROP TEST
A voltage drop test is the only effective way to find excessive resistance in high amperage circuits. It's a quick and easy test that doesn't require any disassembly and will quickly show you whether or not you've got a good connection or a bad one.
To do a voltage drop test, you create a load in the circuit that's being tested. Then you use a digital volt meter (DVM) to measure the voltage drop across the live connection while it is under the load. Voltage always follows the path of least resistance, so if the circuit or connection being tested has too much resistance some of the voltage will flow through the DVM and create a voltage reading.
If a connection is good, you should find little or no voltage drop and see less than 0.4 volts for most connections, and ideally less than 0.1 volts. But if you find more than a few tenths of a voltage drop across a connection, it indicates excessive resistance and a need for cleaning or repair.
CHECKING THE STARTER CIRCUIT
To check the starter circuit for excessive resistance, you need to measure the voltage drop at the battery, battery cable connections and starter while the engine is being cranked.
The first check is "available battery voltage." For the starter to crank at normal speed, the battery must be at least 75% charged (12.4 volts or higher). Low battery voltage can not only affect the starter but every other electrical system in the vehicle.
A. Set your DVM to the 20 volt scale, then connect meter positive (+) lead to battery positive (+) post (not the clamp or cable), and the meter negative (-) lead to battery negative (-) post.
B. Disable the engine so it will not start when it is cranked. (Ground the ignition coil wire, or disable the ignition circuit or fuel pump relay.) Limit cranking time to 15 seconds or less.
C. While cranking the engine, record the volt reading on the DVM. D. Next, connect your meter positive (+) lead to the battery terminal stud on the starter, and the meter negative (-) lead to the starter housing.
E. While cranking the engine, record the volt reading.
F. Compare the two voltage readings. If both are the same, there are no excessive voltage drops on the positive feed side.
G. If available voltage at the starter is not within one (1) volt of battery voltage, there is excessive voltage drop in the circuit.
The next test is for voltage drop on the positive side of the starter circuit.
A. Make sure the battery is fully charged.
B. Disable ignition.
C. Set DVM on 2 volt scale.
D. Connect meter positive (+) lead to positive (+) battery post, and the meter negative (-) lead to the battery terminal stud on the starter. While cranking the engine, record the voltage reading.
The maximum allowable voltage drop including the solenoid or external relay in the starter circuit should be 0.6 volts or less.
If you find more than a 0.6 volt drop in the starter circuit, you can isolate the bad connection by using the following voltage drop tests.
* Check the positive battery post and cable connection by measuring the voltage drop between the two while cranking the engine. Connect the meter positive lead to the battery post and the meter negative lead to the cable clamp. A good post/cable connection should have zero voltage drop.
* Check the positive battery cable by measuring the voltage drop end to end while cranking the engine. Connect the meter positive lead to the clamp on the positive battery cable, and the meter negative lead to the end of the cable at the starter. Crank the engine and note the voltage reading. A good cable should have a voltage drop of 0.2 volts or less.
* To check the starter solenoid or relay connections, connect the meter positive lead to positive battery terminal on the solenoid or relay, and the meter negative lead to the starter motor terminal. Crank the engine and note the reading. A good connection should have a voltage drop of 0.2 volts or less.
Next, you need to check the negative side of the starter circuit. To check the entire circuit, connect the meter positive lead to a clean spot on the starter motor case and the meter negative lead to the negative battery post. Crank the engine and note the reading. The voltage drop on the negative side should be 0.3 volts or less.
If the voltage drop is too high, set your DVM to the 2 volt scale and start checking each connection on the negative side to find the bad connection or cable. Use the DVM leads to check across each connection while cranking the engine as before.
Check the negative battery post/ground cable connection (should be zero voltage drop).
Check the negative ground cable from the battery to the engine (should be 0.2 volts or less).
Check between the negative battery post and starter housing (should be 0.3 volts or less).
Check between the engine block and starter housing (should be 0.10 volts or less).
CHECKING THE CHARGING CIRCUIT
To check the alternator connections on the positive side for excessive resistance:
A. Set DVM on 2 volt DC scale.
B. Connect the meter positive lead to the alternator output stud (B+ terminal).
C. Connect the meter negative lead to the positive (+) battery post.
D. With the engine running at 1,800 to 2,000 rpm with all lights and accessories on (except the rear electric defroster), check the voltage drop reading. It should be 0.5 volts or less. If higher, the connections between the alternator output stud and battery need to be cleaned. Also, look for loose connections or undersized cables.
To check the alternator connections on the negative side for excessive resistance:
B. Connect meter negative lead to alternator case.
C. Connect meter positive lead to battery negative (-) post.
D. With engine running at 1,800 to 2,000 rpm with all lights and accessories on (except rear defogger), check the voltage drop reading. On the negative side, it should be 0.2 volts or less. If excessive, the connections need cleaning or the negative cable needs to be replaced. Some alternators are mounted in rubber bushings and have a separate ground strap. If so equipped, be sure to check the voltage drop across this strap, too.
egulator checked with voltmeter?
Nov 15, 2009 | 1997 Jeep Grand Cherokee
2500 dell inspiron fails to boot when new fan comes on
You are drawing too much current from the power supply with the current hungry fan.Try using a different fan that draws less power on start up. Or use a limiter to lower the input voltage draw on start up. These are usually found in fan speed controls You could also use a voltage dropping adaptor like the one use to quite fans down . They drop the 12 volt voltage to 7 volts by connecting the two voltages usually found on the power connector 12v and 5v and and adding them together getting a 7 volt output. You can also try connecting the fan directly to the power supply and avoid using the motherboard connector.The problem with this is you will not get use of the speed controling sensors used in the motherboard connections. Hope this helps you with your problem.
Apr 29, 2009 | Dell (6F858) Cooling Fan
DTV H20-600
I do not have an schematic for this receiver. This receiver might not use LM317 or TIP42C but a different voltage regulator, try to locate where the 20 volts line from the power supply and follow it to anywhere near the LNB tuner circuitry. This type of IC is normally mounted on a heatsink.
Lastly if you are a subscriber, give you satellite service porvider a call to get a replacement.
Nov 08, 2008 | Philips DIRECTV H20 DTV Receiver
DTV H20-600
Before we get into measuring any voltage. Read the info from this link and see if that applies to the receiver that is acting up on you.
Nov 02, 2008 | Philips DIRECTV H20 DTV Receiver
DTV H20-600
You could check the voltages yourself to see if they are low. The horizontal polarity needs about 19 volts and the vertical polarity about 14 volts to work properly. If those voltages are lower by 25%, the receiver might failed to scan and that is when it locks up because is trying to find signal. The other issue could be a defective power supply if the receiver does not work after that 4 hours. There could be some capacitors that lost their dielectric strength causing the drop in voltage.
Let me know if you need further assistance.
Nov 01, 2008 | Philips DIRECTV H20 DTV Receiver
Voltage drop test
First, check battery post to cable connection: positive meter lead on battery positive post, negaitve lead on battery's positive cable clamp. Crank the engine and note the reading. A good connection should have zero voltage drop. Second, check the positive cable: positve meter lead on positive battery clamp, negative lead on starter terminal connector. A good cable will show a voltage drop of .2 volts or less while cranking. Third, check the starter connection: positive meter lead on positive battery terminal on the solenoid, negative meter lead on actual starter stud. A good connection will have a voltage drop of near zero volts. Now to check the negative side of the circuit. Total drop on the ground side should be .3 volts or less and can be checked by placing positive meter lead on starter housing and negative meter lead on battery ground post. Take your reading while cranking the engine, and be sure your connection at the starter is solid and clean. If total voltage drop on this side of the circuit is excessive, complete testing at all connections in the same fashion as the positive side of the circuit. Check the following: between battery post and clamp (zero voltage drop), cable end at battery to cable end at engine. (.2 volts or less), cable end at engine to engine itself (near zero voltage drop), and finally between starter housing and engine block (.1 volts or less).
To read the entire procedure for all automotive systems read this artile:
http://www.engine-light-help.com/voltage-drop.html
Aug 31, 2008 | 1997 Chevrolet Blazer
Searching for Satellite
The voltage is supplied by the power-supply through the RF/IF interface usually encased in a metal box on its own. Also without knowing the model number of your unit I cant help any further.
May 16, 2008 | Hughes SDHBH DirecTV DTV Receiver
Philips DIRECTV H20 DTV Receiver Logo
749 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
