Question about JVC AV-32F703 32" TV
Difference between JVC AV-32F703 and AV-32F704?
Anyone know the difference between the JVC AV-32F703 and AV-32F704? I have a bad picture tube in the 703 and can get a 704 with a good picture tube but that may need power supply repair. Hopeing to swap parts from 703 to 704. Thanks--
  • Bert Mar 10, 2008
    Thanks for responding. I decided to take one more crack at this. Originally I found that there was a 4-5Kohm short between the screen grid G2 and G1 probably due to some crud inside the tube. I blew this open with a charged cap. It fixed the problem but only for about 5 minutes then my screen went black again with a 1Kohm short this time. Well I charged a cap again and zapped the crud but this time it must have splattered the focus grid cuz my screen voltage now shot up too high and varied with focus control. I removed the picture tube board/connector and checked for shorts but found nothing within the range of my 10 Megohm meter. I calculated, based on the measure voltage that the short was very high impedance -- > 25 MOhm. Anyhoo, I fiddled with it a bit more and then gave up.
    After posting this I got re-inspired to try again. This time I disconnected the feed resistor and filter cap to the screen grid and fired er up. I was hoping that the 6KV focus voltage would self-zap the crud. When I put the circuit back together my screen voltage was close to normal and my picture was back! It's been running for several days now and still working (fingers crossed).
    Thanks for your help.
    Scholar:
  • 52 Answers
If the connector at the back of the tube (several wires) is the same, then you should be able to switch the tube if the "horizontal and vertical deflection connectors are also the same. If you are not a tech, you probably don't want to try this, but if the horizontal and vertical deflection connectors are not the same, then you MIGHT be able to cut the 4 wires and interchange the connectors. These wires come from a whole bunch of copper colored wire that is wrappped around the back of the tube. The wires looks like it is not insulated, but it actually is dipped in some sort of "stain-like" insulation very similar to electromagnetic wire. The 4 wires coming from this stained wire are usually white, black, red, and yellow and are usually a little bit bigger than most of the other tv wiring. Sometimes, that all go to the board on one 4 pin connector, whereas sometimes, there will two connectors with two wires each.
If both sets are torn up, then you have nothing to lose by trying. Be very careful about the big red wire coming from out of the glass part of the tube. If you unplug this wire and then touch the glass part of the tube where it was plugged into, you will get a punch of about 12 to 18 thousand volts. It's very low current and a very brief shock, but it feels like you have been hit with a sledge hammer. I have been "hit" once and I promise you, it will never happen again. Take a screw driver and connect a wire to the screwdriver. Connect the other end of the wire to "ground". You should see a bare ground wire wrapped around the tube. Then stick the screwdriver under the flat rubber insulator where the red wire plugs into the tube and you will hear the spark when it discharges. MAKE SURE THE TV IS TURNED OFF BEFORE YOU DO THIS OR YOU WILL BLOW UP THE WORLD! Good luck. Should be a fun project. Just be careful. Keever
Posted on Mar 08, 2008
    Sergeant:
  • 395 Answers
The tubues are not the same the 703 is part number A80AJZ90X03 and the 704 is pert number A80ERF042X17
My JVC tv picture has only one quarter of the screen
Hi. 1/4 screen. Horizontal or vertical ? Makes an important difference. I need more details, like typenumber f.i. Also, you must be able to carry out repairs on this electronic circuitry. Otherwise it makes no sense talking about components etc.
Oct 12, 2014 | JVC AV-27230 27" TV
I have no picture on my JVC AV-27730 tv. Where is the picture tube and can i replace it myself?
Hello
Picture tubes are available at electronic spare part shops. You have to give them the number and type of the picture tube, to which your JVC TV has. Picture tube, along with its Yoke fittings are integrated, and you can replace it by yoursef at home. Be very carfull in handling the picture tube, as they are highly vacumed, and will explde by hard hits. There will be four seating screws on the four corners of the picture tube, and these slots will clearly alaign if the picture tube selected is orginal number. Diamentions of these holes will be different to spherical and flat picture tubes. So you must first aware of the type of picture tube, which the TV has fitted earlier. OK.
Mar 06, 2011 | JVC AV-27730 27" TV
JVC AV-56WP30 has red onlines in picture (maybe red bulb ?)
This is a 2002 model----if picture looks 3d it has a convergence problem---if you go into the customer menu with the original remote select convergence and see if it will adjust----IF the answer is no, let me know and I can tell you what is involved to repair this problem.
SD TECH
Sep 30, 2009 | JVC AV-56WP30 56" Rear Projection...
My 48 inch jvc tv has a green color to it what can this be and how can i get it fixed
Okay so the green color that you see on the screen is because the coolant inside of the green picture tube is gone bad (it suppose to be cristal clear but now it is brownish and that makes the green color run all over the screen.) That just happens over time and I'm guessing the picture tubes have never been serviced. Now you got two choices
1- The easiest and fastest way would be to take it to a local repair shop and have them service the coolants of your picture tubes. I'm guessing it would run you about $165 or so to get them done (the three of them red,green and blue)
2-On the other hand you can do it yourself. It is not hard at all but it does require a lot of attention.
After the picture tubes have been serviced you'll notice the big difference.
You'll actually have a much brighter and sharper picture just like when it was new.
Let me know if you decide you want to do it yourself so i can post the instructions for you.
Jul 13, 2009 | JVC AV-48WP74 48" Rear Projection...
Dark screen
the sound is locked off the TV good picture
Feb 20, 2009 | JVC AV-27320 27" TV
What's the difference between AV-48WP30 and AV-WP74
They are both the same size screen. (48" diagonally)
width: 106.3cm
height: 59.8cm
C-Dog
Feb 01, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC tv AV-27D304
Roger, if your contrast (sometimes called picture) and brightness controls are at max you can increase the tubes brightness by turning the "screen control" clockwise, be advised a little turn goes a long ways, don`t crank it too far or you will get retrace lines, you will have to remove the back from the set and follow the red wire down from the tube to the "flyback transformer" on the front of the flyback are 2 controls, focus and screen, do not move the focus control, this should fix your problem.
Nov 20, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC 48WP74 HDTC rear projection
While it is true JVC tubes rarely fail, they can give trouble.
Another possible solution is bad screen / focus block......
Remove lower front grill panel and access board...Check for
smooth adjustment of RGB screen and focus.....let me know....T..
Sep 28, 2007 | JVC AV-48WP74 48" Rear Projection...
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
JVC AV27320 Screen too dark
hi solution #2 was correct. the adjustment knobs r on what's called the "flyback" i adjusted the bottom knob and the difference was from "night to day" !!!
Oct 12, 2006 | JVC AV-27230 27" TV
JVC AV-32F703 32" TV Logo
99 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
