Question about Kodak EASYSHARE 5100 All-In-One Printer
Kodak CX7430 can only take 10 pictures with a new battery
I am wondering why Kodak CX7430 can only take 10 pictures with a new battery. This has made a big trouble when I am going abroad for visiting. Is this a design problem for Kodak digital camera? Camera batteries lose their charge quickly. I have been using rechargeble batteries and changer to no avail? I have trouble turning my camera on. When I turn it on, it doesn't come on but the little red light(that turns green when the camera is on) flashes. I have to turn the camera off, pop out the batteries, put them back in, & then sometimes the camera will come on but not always. I've put brand new batteries in it & made sure it stays on the dock to be charged & kept it off the dock with the batteries out to see if that helps...NOTHING! I don't even bother trying to pics.
    President:
  • 2,761 Answers
Chances are that the problem is corroded battery contacts inside the camera. Remove the batteries and clean the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue that's in the camera from the cleaning, then reinstall your batteries. Hopefully this will cure the problem and get the camera back up and working the way it should.
If that doesn't do the trick, you might want to try your luck with the Kodak Troubleshooting guide at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
Posted on Aug 09, 2009
  • Bill Buchsbaum
    Bill Buchsbaum Aug 15, 2009
    Remove the batteries and clean the battery contacts inside the camera
    with a soft cloth (a heavy buildup on the contacts may require cleaning
    with a fine wire brush, steel wool, or sandpaper). Remove any residue
    that the cleaning leaves in the camera, and then reinstall the
    batteries. This clears most power-on problems, but if yours persists,
    check the Kodak troubleshooting guide at:
    http://www.kodak.com/global/en/service/r...
  • Bill Buchsbaum
    Bill Buchsbaum Aug 16, 2009
    This problem is frequently due to corroded battery terminals inside the
    camera. Remove the batteries and wipe the terminals with a soft cloth
    (heavy corrosion may require a fine wire brush, steel wool, or
    sandpaper). Remove any residue left in the camera by the cleaning.
    Clean the terminals on the batteries in the same manner, and then
    replace them in the camera. This cures most problems, but if it
    doesn't work for you, check the Kodak troubleshooting guide at:
    It uses a simple Q&A format to diagnose problems and propose solutions.
My camera is less than a year old.I have put in new batteries.Sometimes it will turn on,sometimes not.
I bought a kodak c182 for my daughters wedding. it work wonderfully, but now I have a problem with the batteries. I can put in new batteries take 1 picture, then it says low battery and shut off. I have place seveal new batteries in and get the same results. Could it possibly be a promblem with the memory card.
Mar 15, 2011 | Kodak Easyshare C182 12MP Digital Camera
The Camera will randomly turn itself off, batterie...
its better use Kodak battery for you Kodak camera.FYI there's a lot of brand of AA battery like energizer,duracel and also kodak.if you compare the size or the height of all battery its totally different.especially the kodak are more taller than the other.thats why if you use other brand it works only 5 shots only or less.
May 21, 2010 | Kodak EasyShare C875 Digital Camera
Camera is saying batteries are no good. They show plenty of life
Please update to the latest firmware from the Kodak site and try if the problem gets resolved
May 01, 2010 | Kodak EasyShare Z650 Digital Camera
Kodak C180 for Xmas - The pic of the battery shows
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). The batteries that was in your pack when bought are only test batteries and not rechargeble.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 04, 2010 | Kodak EasyShare C180 Digital Camera
Batteries in my kodak easyshare camera don't last
Here are the steps:
Dec 08, 2009 | Kodak EasyShare Z812 IS Digital Camera
Batteries are always dead
You need to get some decent rechargeable batteries unfortunately standard batteries are just not good enough and lose their charge very quickly not to mention end up costing you a small fortune to replace.
I recommend NiMH 2500mah recharageable batteries or better (i use Energizer). Makes sure you have another 2 sets full charged and ready to go so you dont get caught out when out and about.
If this helps,please vote...thanks and good luck!
Jul 28, 2009 | Kodak EasyShare One Digital Camera
Kodak Easyshare
Remove the batterty andclean the internal battery contact with an
eraser on the end of a pencil- take a flash light to look inside the compartment to enfure they are bright and clean.
Make sure the battery door and contact srip are a good tight fit
Hold the door down with a finger whilst switching on
Other than that there is little moreyou can do
Jun 28, 2008 | Kodak EasyShare Z740 Digital Camera
Always use the best batteries you can buy. Either rechargeable or Alkaline. Do not use the cheapest, just because they cost less.
There can also be problems with the camera. This camera, I believe is a 4mpxl digital camera. It has a few years on it (about 2004), and in those years some of the digital cameras did need a lot of power to operate correctly.
My guess is that you are using cheap batteries, not the best you can buy.
Feb 24, 2008 | Nikon COOLPIX L3 Digital Camera
No power
Directly from Kodak's website:
IMPORTANT
We recommend that you do not use alkaline batteries in EasyShare cameras because they may cause unexpected shutdowns and loss of pictures.
Jan 19, 2008 | Kodak EasyShare CX7300 Digital Camera
Kodak V550 Camera Problems
Sounds like a new battery would do wonders. I would contact Kodak and see if hey will offer you a new battery. If not then I would go buy one. The battery is probably the most likely to go bad so fast on a camera.
Aug 23, 2007 | Kodak EasyShare V550 Digital Camera
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
