Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Simplicity vacuum My vacuum just cut off and now it wont start. I pressed there restart button but nothing happens I have 2 fairly old Industrial hitachi dry vacuum in my workshop both 110v and both wont start. Both i was told were manufactured in Italy and both have a manual and auto switch. It has a black top, takes an orange paper filter inside and its bin is dark blue. Sorry i've forgotton the model number. I've inspected the wiring but it's fine, could it be the motor and how do i gain accesss to it?
  • 75 Answers
Just take it in to your vacuum store.
Posted on Jun 30, 2009
No power what do I do when I stopped and tried ti start again no power . Emptied it and cleaned filter but still not working
All vacuums generate heat and some have automatic cut off switches when the vacuum does overheat. When this happens the manufacturer does not want you to just turn it back on, they want you to know there was a problem and to let it cool down. They often do this with a restart button. Having to press a restart button is supposed to make you think a bit more about the problem and, perhaps, let the motor cool down before restarting the vacuum. The button is often small and red.
Sep 15, 2014 | VAX Appliances Vax X3 Bagless Upright...
Simplicity symmetry vacuum stopped working
There is a reset button on the back that trips if the vacuum gets hot.
Jul 27, 2014 | Simplicity Vacuums
Dirt devil canister power wand wont work
first find and locate belt if in good shape prolly aint bad and may be motor lock up
Nov 11, 2012 | Dirt Devil Vision Cyclonic Canister...
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
Fairly new Platinum series Hoover Max extract wont turn on
I have the same problem. Fairly new machine, only been used a handful of times and now it wont turn on.
Feb 18, 2010 | Vacuums
How do I replace the electric cord for my Simplicity Shadow Vacuum cleaner model S13L? It's a canister cleaner.
Since the problem was with the plug on the electric cord, I replaced the plug, I cut the old plug, peel off the plastic cover on the cord, they were two wires, black & white, I purchased a new plug in a Home center, attach the wires to the new plug and it works just beautiful now, it was a two prong plug, which made it easier to fix.
Feb 16, 2010 | Simplicity Vacuums
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Overheated vacuum
It normally won't over heat unless the bag is too full, the filters are clogged, or you have have a clog in the hose or down by the brush roll, the inlet may be clogged. Some will restart after a while, some others have a reset to push. If it won't power on, then you have a problem and it will have to serviced.
Mar 20, 2008 | Simplicity 7850 Premier Bagged Canister...
Simplicity vacuum
Could be a bad cord or a switch problem. Could also be a problem with the motor. Will have to checked to find the right problem.
Oct 27, 2007 | Vacuums
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
207 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
