Help me to resolve a problem with my harman Kardon HK 3380
I bought a Harman Kardon HK 3380 to ebay, and it was working ok, but I moved to other place and plug it; when I switch it on the only signal is PROTECTED, and then turn it off all the times; how can you help me?
  • Anonymous Mar 11, 2009
    I have the same problem.
    Try to reset the receiver first.
    Helped for me.
    Good luck.
    Jo
I'm having the same problem only difference is I baugh my product new, i love my reciver when it works I'm convinced the product is built like everything else these days cheap with no pride, designed to malfunction so hard working Americans like myself pull out of pocket to replace the product being a different brand or what, cuz large corporations repeatedly screw the little man time and time again for years and believe me folks it's only gonna get worse if the little man sits back and does nothing.. I personally do NOT recommend this product costumer service with this product also burns my as# it's a waste of time on your behalf.. Thanks for reading hope to hear from many of you.
Posted on Nov 10, 2011
Hk 3490 receiver on protection mode....what it means and how to correct that
You can try a factory reset after checking your speaker wires for shorts. The procedure is in your owner's manual. This will most likely not resolve your issue. If you need further assistance, or would like to inquire about repairing your Harman Kardon, please visit my website at audioserviceclinic.com and contact me there. BTW, I worked for Harman, as Technical Support for all Harman, JBL and Infinity products.Thank you.
Apr 07, 2014 | Harman Multimedia Harman Kardon HK 3490...
Harman/Kardon AVR 3650 3D A/V Receiver
Make sure TV's HDMI port is working if it is working check it with a new HDMI cable changing the HDMI cable will fix the problem
Dec 15, 2017 | Harmon Kardon Harman/Kardon AVR 3650 3D...
How To connect Bose speakers to hk3380 receiver with my sharp hd tv
Step 1:
plug bose speakers in the little holes on the receiver
Step 2:
then turn up the volume and ur done
Feb 23, 2013 | Harman Kardon HK 3380 Receiver
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
Does the 3380 hk have an optical conecction?
No, it doesn't. But is a great stereo amplifier.
Kostiko
Aug 31, 2011 | Harman Kardon HK 3380 Receiver
Need the AC 15V 1.1a power supply
Hi Tracy,
Wow, this was a hard one. I called both Harman Kardon and Dell, seems HK made the speakers for Dell, but neither company carries parts any more. I called Radio Shack thinking they would have a generic power supply, not even close. I looked at several places on the internet and had no luck.
I do have a little good news, I was able to find a few on Ebay, so if you don't mind buying used, you can get a power supply there. They even have a Buy Now offer so you would not have to bid on it. The power supplies are listed as 1100mA which is the same as 1.1A.
Also, if you get the it and the plug in is not the right size, take the speaker to Radio Shack and they will be able to sell you the correct plug, all you will have to do is splice in the new plug. With it having an AC output, you don't even have to worry about the wires being crossed as you would with DC. Hope this helps you.
Here are the links:
http://cgi.ebay.com/Harman-Kardon-A481511OT-15V-1100mA-Black-AC-Adapter_W0QQitemZ190450725250QQcategoryZ79846QQcmdZViewItem
http://compare.ebay.com/like/370463130288?ltyp=AllFixedPriceItemTypes&_dmd=Gallery&var=sbar&rvr_id=189044360544&crlp=1_263602_304692&UA=L*F%3F&GUID=0234523512d0a0b3f8f79f17ff3c9895&itemid=370463130288&ff4=263602_304692
http://cgi.ebay.com/Harman-Kardon-A481511OT-HK-01T-AC-Adapter-15V-1100mA_W0QQitemZ190450725272QQcategoryZ79846QQcmdZViewItem
Dec 23, 2010 | Harman Kardon HK19.5 Computer Speakers
My HK 3380 doesn`t turn on...
If the display does not turn on, then you have a power problem. The unit is not completely turning on. Since you opened up the unit, give it a sniff test to see if there is any burnt odor inside the unit. Check the fuses also. Have a look at the transformer board. It may have several fusible resistors sitting high on the board. If they burn open, there is no power to the display/cpu board.
Mar 22, 2010 | Harman Kardon HK 3380 Receiver
189 people viewed this question
 Grubhead
Grubhead
