I had a problem with my Blackberry bold 9000 where my keyboard stopped responding, this was probably due to humidity and it was fixed by good bowl of rice. Now I have a problem with several keys, it seems like when I press them two actions are made (i.e. when I press the letter 'i' the '$' sign is also pressed and when I press on the '$' the 'i' is pressed. Any ideas? thanks for your help!
If your BlackBerry Bold 9000 series device is frozen or not responding, you will probably want to reset the unit. Here are the different types of resets that can be perfomed in the order they should be tried. Soft Reset PressALT + RIGHT SHIFT(CAP) + DELETE. Double-Soft Reset PressALT + RIGHT SHIFT(CAP) + DELETE. The screen will go blank for a few seconds. When the screen comes back on, immediately pressALT + RIGHT SHIFT(CAP) + DELETEagain. Hard Reset If none of the above works, pull the battery out of the unit for a few seconds, then reinsert it.
You volume button needs to be replaced. If you want to do it yourself, the good
news is, it's not too hard to open it. Here is an Blackberry Repair Guide that shows how to open a Blackberry. If you want somebody else to do it for you go to Blackberry Repair.
Your phone has been blacklisted from whatever carrier you're trying to use. The solution is to unlock (go to www.unlockbb.com if it's not unlocked already) and try another carrier.
There can be many ways to Unlock your phone.As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry BOLD 9000 and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry BOLD 9000 online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
Try getting some canned air and blowing out the keyboard. Make sure the can is held upright and does not tilt while blowing it out. If that doesn't work, bring it to your carrier store for repair, or call Blackberry support.
http://na.blackberry.com/eng/legal/handheld_warranty.jsp will give you warranty and contact information for your Bold.
It's a clear and fully detailed guide on how to unlock a BlackBerry Bold 9000 :
1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (if your BlackBerry have touchscreen) 7. Type MEPD ( you will not be able to see what you are typing ) 8. Type MEP2 or MEP4 ( you will not be able to see what you are typing ) 9. Now the phone will prompt you to enter the mep code 10. if you not already have the code, then i suggestBlackBerryMEP.COMto get it from . 11. Enter the mep code ( you should see "code accepted" ) 12. Restart your BlackBerry .
