Tv repair Sony KV20S10 Trinitron Color TV manufactered 8/1994 has only snow and no sound on all channels when turned on. After undetermined time both perfect picture quality and sound appear. If TV is turned off and back on same problem arises. TV operates with local antenna (rabbit ears) and problem started sometime after cable service was discontinued. Any ideas?? Thank you.
  • bill bones Mar 09, 2008
    Thanks to Keever for the response.
    I really appreciate the response but I had already made sure the "cable" was set to Off right after cable service was discontinued. Keever's solution makes sense for 99.99% of the time, but unfortunately for me I'm apparently in the .01% group.
    Scholar:
  • 52 Answers
Your tuner (in the tv menu) is probably still set on "cable", but it should be set on "off air" or "antenna". When you first turn it on, it looks for a cable signal and when it can't find one, it automatically searches for an "off air" or "antenna" signal. Once it finds a signal, then it stays on and runs ok. If you shut it off, then it has to go thru all this again.
There is a very high probability that this is your problem (about a 99.99% chance). Just go into your menu and select "tuner" or tuning or "input select" or something in that "neighborhood". Different TVs call it different names, so just put in on the option other than "cable". If you ever get cable back again, then, of course, you have to go back into your menu and set the tuner to "cable. Hope this helps.
Keever
Posted on Mar 08, 2008
  • mack paulk Mar 10, 2008
    Ok, if your set is small enough then take it to a friend's house (who has cable or dish) and see if it will play ok on one of those (Don't forget to set the menu back to cable). If so, then something is wrong with your rabbit ears, your rabbit ears cable, or your rabbit ears cable connector ends;-------OR your "antenna/off air" input circuits which are probably all located inside the tuner, itself. But before you try this, have you wiggled the rabbit ears cable where it goes into your tv and also where it comes out of the antenna device? If you are lucky, it could just be a bad connector. Another easy fix (if you are lucky) is to bumb the top of the tv and the back with your hand WHILE the tv is malfunctioning. You might have a "cold solder joint" and if so, many times a moderate jolt will temporarily give you a pic and sound. Other times, the tv will just flash or jitter a little bit every time you bump it. This "jitter when you bump" is not normal for a properly working tv and usually means a cold solder joint. Keep me posted and I'll stay with you until we either fix it or hit a dead end. Thanks for your response. Keever
When I turn the tv on (vega fd trinitron) the scren is all snow. There is no signal.
Hello
Have you tested it with auto tuning progremme process. If it snow there, your TV may be working properly. Sometimes its signal input path is not Ok. Without any signal, all TVs may show either snow, or a plane blue raster if its blue back function is on. You just do the automatic tuning process once again after connecting it with an external or internal antenna. There is a socket provided there in the back side of your TV, and marked as VHF/UHF. Connect the signal source to it first.
And set your TV to autotune by slecting it from the menu of your TV. The TV will search for all the channels available at that time, and after searching is completed, it will stop and show the first channel received. Afterwards you can chage or delete or skip unwanted channels. You may have its manual with you. All the descriptions are there in that manual. Ok.
Oct 30, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony kv-36FV300 will not respond. won't turn off .....or turn stations. The picture is snow...and has a "7" in the upper right hand corner. ....and has "no signal" in lower left corner.
Just wondering if thesmiths860 found a solution to their issue w/ their Sony TV. My tv is doing the same thing i.e. snow, won't change channels and says "NO SIGNAL".
Does anyone have a solution? I don't have the original remote so I can't do a factory reset.
May 04, 2010 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony trinitron wega kv-36fs200 36' tv is missing green color
sounds like a major fault with the line output transformer/power board. if no green on screen, tube is on it's last legs. Advise to scrap, not to repair, cost in excess of £200
Oct 23, 2009 | Televison & Video
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony tv
Please resold all pins of IC001 in main board of TV. Problem will be solved.
Aug 08, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
KV35540 Sony Trinitron
pls check the antina or the cable line or the cable plug or call the tech.
in the tv tunner foulty
Jun 07, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
TV is cutting in and out of color
My sony Trinitron TV just shows a padlock on the screan.Please help me unlock it.
Mar 16, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony TV snow at startup
Bad solder connection in tuner.....replace with new or rebuild.
............................T.
Mar 09, 2008 | Televison & Video
Sony Trinitron Model KV 20M20
You may have a bad H board which is the board that has the voulme/channel buttons on it. You may want to have a Sony asc give you an estimate to repair. Good Luck
Dec 04, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
No picture or sound
If you see only snow and the words "NO SIGNAL" are displayed, and you know that you have the set hooked up to a good signal and the TV is set to the right channel, it means that your tuner has stopped working and needs to be replaced. First, though, make sure your signal is good. A good way to test this is to hook the TV to a good VCR, put in a good pre-recorded tape and hit play. Tune the TV to channel 3 (or 4) and if it is still all snow, have the tuner replaced by a qualified tech.
Sep 03, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
