Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
Nx9010 power on problem
My compaq nx9010 skips directly to setup on powering on
  • 520 Answers
Choose load default settings then save and exit.
then we;ll go from there.
keep me informed
Posted on Mar 08, 2008
Hp nx9010 error 280
Here is the info for the error 0280
0280 Previous boot incomplete-Default configuration used
Previous POST did not complete successfully POST loads default values and
offers to run BIOS Setup If the failure was caused by incorrect values that are
not corrected, the next boot will likely fail This error is cleared the next time
the system is booted
Here is the direct link to the Maintenance and Service Guide
http://bit.ly/gBwWBa
Good Luck
Mar 07, 2011 | HP Compaq nx9010
I need bios password for compaq nx9010 plese help
y this procedure. It very serious problem. For someones...
To remove that password there are few steeps:
0. remove AC power
1. remove system battery (primary and multibay if present)
2. remove harddrive from harddrive bay
3. remove Multibay Devices from multibay
4. remove small round battery pill 3.3V, located under a cover on left side of touchpad. Remove cover gently (is no need to remove keyboard, but cover is removable with some power...) Delicate unplug small conector with cables leading to battery,
5. wait 5 minutes
6. connect AC power
7. Turn on computer unit (BIOS gets a few errors = date, time, mismatch etc. no need to panic, if everything is ok then get into computer setup pressing F10, change existing setup values as needed, if ok power down computer.
8. unplug AC power
9. Plug small battery into motherboard
10. install Hdd and multibay devices
11. Install system batteries
12. Power Up computer, there could be no password anymore
Jul 03, 2010 | HP Compaq Presario 2500 HP Pavilion ZE...
My hp compaq nx9010 wont power up. dc supply is good and the batteries are ok. No led light...
This is a typical symptom of motherboard failure. Your laptop's motherboard will need to either be serviced or replaced.
Feb 16, 2010 | HP Compaq Business Notebook NX9010
Compaq nx9010 startup buttom doesn't work
1>>Shut down the computer and restart the computer and while restarting computer keep tapping on F10.
You by this go to BIOS screen , press F9 here and then F10 to save the defaults and to exit out of BIOS
2>>In the Control Panel click on Power Options and here click on Choose what the power button does and set the option accordingly
Jan 25, 2010 | HP Compaq nx9010
PC suddenly lost power will not restart
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Dec 05, 2009 | HP Compaq nx9010
Nx9010 goes to standy
some of these laptops you have to press the power button to come out of standyby.
Jul 31, 2009 | HP Compaq Business Notebook NX9010
Setup problem
when u say setup do u mean bios setup or windows setup.if windows setup u have os disk in cd.if not , in bios choose save and exit if no joy have hd problem maybe need to reinstall os.
Mar 08, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Laptop wont power on!!
I would suggest first formatting the hard drive and then go from there, If that is feasible for you... Good luck... GURU JAY
Jan 30, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Compaq nx9010 powers down to stanby.
select control panel off computer menu then select performance and maintence icon then select power options then you will see power options properties options tabs.. set properties to suit your needs
this should solve your problem
Jan 12, 2008 | HP Compaq Business Notebook NX9010
Compaq Business Notebook NX9010 runs on battery only???
If it charges the battery but won't run on AC (without a battery) then something on the motherboard is probably faulty.
Nov 28, 2007 | HP Compaq Business Notebook NX9010
Computers & Internet Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
