Question about Amana AFD2535DES French Door Refrigerator
Loose handle on fridge freezer door.
I have an Amana 25 cf bottom freezer fridge. The handle on the freezer is loose. How do I get the handle off so I can tighten the clips on the door?
  • 1 more comment
  • proplants Mar 08, 2008
    The handle on the freezer drawer is loose. I had this fixed by a repairman over a year ago. We've had the frisge for aabout five years. How do I get the handle off so I can tighten the clips?
  • Anonymous Mar 27, 2014
    Cannot fix the bottom of the handle back onto the fridge door
  • Anonymous Mar 28, 2014
    This is the French Door Bottom freezer model#GX2FHDXVQ03
    President:
  • Amana Master
  • 2,651 Answers
That handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Posted on Mar 12, 2008
  • rogschappe
    rogschappe May 14, 2012
    Mine came off by pulling to the left. it looks like the clips can be installed either way as long as they are installed the same way on both sides.
How do I do fix the handle of my Matag refrigerator #M1TXEMMW803. It is loose on the bottom.
Maytag Repair - YouTube
? 2:17
https://www.youtube.com/watch?v=KcPy_PWb_Iw
Aug 27, 2013 - Uploaded by hpaiz69
Maytag Side by Side Loose Door Handle Repair. ... RefrigeratorDiagnostic & Repair - Not cooling ...
LG Refrigerator Repair (Part #AED37133117) - YouTube
? 1:01
https://www.youtube.com/watch?v=BXupc6y_wgw
Jul 9, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the handle is when it . ...Fridge Freezer Door Handle Replacement ...
How to fix a loose Refrigerator Handle - YouTube
? 0:30
https://www.youtube.com/watch?v=4IO60zkMXpw
Dec 12, 2013 - Uploaded by Charles Joyner
How to fix a loose Refrigerator Handle .... Refrigerator Repair - Door & handle, Amana , Whirlpool, Maytag ...
Jan 05, 2016 | Cars & Trucks
The freezer handle is loose on one side. How can
Check to see if your freezer handle has an inlay in the handle or trim that pops off to get at a screw that holds the handle onto the door. If you don't have this then you may have a handle that literally slides up and off. You then tighten the mounting screws or replace the handle if that is what is making it loose. We no longer can tear apart the doors on refrigerators to get at components inside, because the factory puts these together and shoots liquid insulation into the cavity, and this insulation expands and hardens making it impossible to tear doors apart anymore. This is why most handles now are front repairable. Good Luck. Appliance Specialists
Dec 11, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Door handle are loose
get a 2.5 allen wrench and tighten the bottom side of the handle
Nov 15, 2009 | Fisher and Paykel RF201ADUX Bottom Freezer...
The handle on the door of my bottom freezer Amana has come off where it is attached in one of two places to the door. The handle was held in place by two screws. They have come loose and there is no way to...
Push the handle in and slide it to the side. It should come off and you can tighten the screws and re-attach the same way. I just about destroyed my door before i figured this out.
Aug 03, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer door handle loose
u could always set the handle in place where it needs to be and use caulk or super glue to go around the handle and that should help it stay in place if that doesnt work the website www.amana.com to see if it has warranty for the broken handle good luck
May 26, 2009 | Amana ABD2233DES Bottom Freezer...
Bottom freezer door handle loose
There is a plastic card that you are supposed to slide under the right side of the handle. Once you have done this correctly the whole handle should slide off to the left.
Nov 14, 2008 | Amana ABB1927DE Bottom Freezer...
Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Nov 07, 2008 | Refrigerators
Bottom freezer handle
At both ends and actually inside the ends of the handle, are small metal brackets that are attached to the door face by a single screw.
You access the screws by pulling the plastic plugs, using a very small and thin flat bladed screw driver.
My handle was loose but hadn't come off on it's own. But I couldn't get the handle to fully tighten.
My fix was to wrap each end bracket with a couple layers of electrical tape (not covering the screw hole) and reattached the handle.
It is now very tight, as it should be.
Jul 17, 2008 | Amana ABB2227DE Bottom Freezer...
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Amana AFD2535DES French Door Refrigerator Logo
1,233 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
