Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Pt-47wxc43g tv
Power comes on i have hooked the cable box up no picture i have hooked the vcr up no picture do i need a converter box or what
  • angeltaxlady Mar 08, 2008
    I was just hooking the cord from satelite box into the back of the tv how do i access the ptv menue? please help i am lost
  • 96 Answers
No ,
Fisrt I need more info, what source of input or you using, video 1, 2 etc... or is it your calbe connection input.
If you or using av cable's, witch I would, connected to source input 1 with video in and two audio in and go to the ptv menue and put in on source input 1.
This should work if it doesn't then you may have cabling problem, ptv problem or cable box problem.
First start by suspecting cable problem, swap the cable to see if you get picture, if not try a differenct source of input a dvd, it should solve your problem
What About Bob
Timmins, Ontario
Home of Shania Twain.
Posted on Mar 08, 2008
I can not figure out how to change the time with my TV being hooked to a converter box with the VCR Sony N-50. Not to mention, I can't get it to show the picture. I think if I could see the picture I could...
See this web page:
for an explanation.
The TV converter box connects to the VCR and the VCR connects to the TV. Be sure you set the TV on channel 3 (or 4) if using a coax cable connection.
Jan 11, 2011 | Sony SLV-N50 VHS VCR
How do I hook up my old VCR to an insignia tv?
You will need a converter to record onto a VCR. I can't remember the when the FCC require VCR to have digital, but I know yours old enough it has an analog tuner. Take your antenna connection to the in on the converter box, then you can take the out from the converter box to the in on the vcr and finally take the out to tv to the tv. To record you have to have the vcr on 3 or 4 and use the converter box to do the channel changing.
Another way would be take the in to the converter and use RCA cables to the line in on the vcr, and line out to the to the tv. This will give you stereo sound.
Aug 10, 2009 | Panasonic Televison & Video
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
How do I scan the channels on a Panasonic 1080i HDTV? This is for the conveter box hooked up to the DVD/VCR to the Panasonic 1080i HDTV'
The cable to the antenna and another cable from the TV needed to be hooked up and THEN follow the directions that came along with the converter box.
Channel 3/4 and scan., be sure the antenna is strong enough.
There was no need to touch the DVD/VCR box.
Jun 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
My Zenith VCR is not working with the digital converter box
When the VCR is "off" the converter signal should go right through the box, which you say it does. Then, when you turn the VCR "on" the picture disappears. That, so far, how it should be. To get your picture back while the VCR is "on" you must set the VCR to "receive" channel 3, and use your new converter box to change channels...accordianman
Dec 16, 2008 | Televison & Video
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Taping to a VCR post converter hook-up
cant you just turn the channel on your DCB and then record on the vcr?
Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
