Question about Grundig G4000A FM/AM Radio
Black Meatal thing
This alos happend in the story explained in my other post http://www.fixya.com/support/t432023-speaker_wires
Wile repaqiring the casing i discovered that this black rod that had copper wire twisted around it had snaped, the part with the wire is fine it's other half with no wire that is broken. Does anyone know the signifigence of this rodd and what I should do with it, Thanks
    Novelist:
  • 155 Answers
The thing you are describing is a ferrite rod. It is the aerial that is used for LW and MW reception. The telescopic aerial on top is used for FM.
Providing it is a clean break and you haven't lost any parts of the ferrite rod, just tape it back together. It shouldn't have too great an effect on the reception.
Hope this helps,
Matt.
Posted on Mar 08, 2008
SOCK PUPPET can you explain again where red &black blue &grey wires go, can't fit into holes , don't know which is left or right speaker
Hello, Tracy -
See your earlier question and the answer by Sock Puppet here:
http://www.fixya.com/support/t26874371-connect_speaker_wires_no_plugs_logic
Note: You could have gone to your Fixya.com account and looked at your earlier question and seen the answer by Sock Puppet.
Best wishes.
Jan 31, 2018 | Car Audio & Video
I am trying to connect a speaker in a shower connected to a tv. The speaker has conventional black and red bare wire connections. How can I connect this to my tv so that I can hear sound from this speaker.
User manual:
http://download.p4c.philips.com/files/4/42pfl7403d_10/42pfl7403d_10_dfu_eng.pdf
As you can see in the user manual, this TV does not have connectors for the external speakers.
It has Headphone out (not strong enough to drive the speakers) and audio line level outputs (not for driving speakers either).
So for you to use the external speakers, you will need a small amplifier that will accept the signals from the headphone or audio line out from the TV to drive your speakers.
As you can see, it will not be easy setup if you do not like to have extra component installed.
You can look for small amp at Radio Shack.
I hope I explain it clear enough without confusing you.
Please leave rating if it helps.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 15, 2011 | Philips 42PFL7403D/27 42 in. LCD TV
No power no screen nothing i opened it up to see any capacitor are blown but they seem ok what do you thank
Capacitors have completely flat tops? Bad cap can look normal but can have high ESR.
You alos need to check the DC voltages on the filter caps.
Please read my guide.
Basic LCD monitor and LCD TV troubleshooting guide:
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find
Nov 14, 2010 | LG Flatron L1718S LCD Monitor
I need help wiring a kenwood cd player into a 1991 ford explorer
Here is a link for your explorer
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
and there should be a diagram on the back of the kenwood deck which would explain the deck side. if not your main power should be yellow = Constant 12V for clock
Red = Ignition 12V switch turn on the deck
Black = Ground
blue purple green white= for speakers
solid color = to positive on speakers
color with black stripe = negative on speakers
I would solder and heatshrink all connections Good luck
Oct 27, 2009 | 1991 Ford Explorer
Car stereo wire diagram for 88 toyota tercel
1988 toyota tercel sedan as follows
pink = (+) pos. for left front speaker
violet = (-) neg for left front speaker
light green = (+) pos. for right front speaker
blue = (-) neg for right front speaker
blue/yellow = (+) pos at all times (power)
grey = (+) pos. only in the accessory or run position
brown = (-) neg gound
red = (+) pos. right rear speaker
black = (+) pos. left rear speaker
white = (-) neg right rear speaker
yellow = (-) neg left rear speaker
verified at 2 resources . fixya
Dec 26, 2008 | 1988 Toyota MR2
Need wiring diagram for 1997 ranger stereo
1997 Ford Ranger Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Purple
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Orange/Light Green
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Jul 31, 2008 | 1986 Ford Ranger 2WD
Car radio wiring color coding.
Specifically for what make and model of head unit pls?
Most current car radio would be using:
Yellow - +12V Constant Power/always on such as the battery's + terminal
Red - +12V Switched (accessory) Power such as the ACC terminal of the ignition switch
Blue - Power Antenna
Blue/White - Amp Turn-on
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
Jun 19, 2008 | Car Audio & Video
I need a wiring harness for my deh-p730
Most Pioneer units follow the below detailed color codes for the wiring.
White/Black - (LF-)
Gray/Black - (RF-)
Green/Black - (RR-)
Jun 16, 2008 | Pioneer Car Audio & Video
I try to fix my pioneer deh2300, but no sound.....
If you have verified that indeed all the wires are connected as to where they are supposed to be connected, pls try:
1. Activating Internal Speaker to ON in the DFS Alarm Function'
2. the brown wire (or whatever color wire it is that is to be attached to a mobile phone) must not be connected to anything;
3. try all sources, AM, FM, CD;
4. check that none of the speaker wires is grounded.
Pls post back for any developments or the lack of it.
Nov 30, 2007 | Pioneer DEH-P4100
Grundig G4000A FM/AM Radio Logo
110 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
