Question about HTC TyTN II Smartphone
Need to repair slide
One of the two sliding tracks has come undone. Is there a simple way to snap the two parts of the phone back together?
  • HTC Master
  • 13,433 Answers
I think we solved this one on live chat.
Posted on Mar 09, 2008
Cant put handle back on
Sometimes the hose that slides on the inside of the handle is coming undone. You will need a new hose.
Sep 05, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
Custom cool drawer sliding mechanism broke
Most of the rail slides, when they break apart, cannot be repaired. It would be better to replace the complete assembly.
Aug 18, 2012 | Refrigerators
I have a 2005 Dodge Caravan with automatic sliding doors. The passenger side has come off the track and I cannot get the rollers back into the right track. Can you help?
The brackets come in two pieces. One that rides in the track and one that bolts to the door. You need to undo the bolts holding the two parts together. Align the piece with the rollers back into the track and then bolt the two parts back together.
Aug 22, 2010 | Dodge Grand Caravan Cars & Trucks
The window keep sliding down. What should I check first. Do the window motor need to be replaced?
I have had two Roadmaster Wagons (we love 'em) with the same problem. The problem I found was only in a plastic clip that the actuator arms snaps into. I have not found an easy solution to replace, but it can be done. Take off the door panel and lower the window some (with help of a friend) so you can see the track at the bottom of the window. In that track there are plastic clips with a socket that a ball from the actuator arms snap into. You will probably see that one (or both of those) is broken. You need to slide out the old clip (you will need to bend out the indentation on the metal track so you can get it out) and slide in a new clip from a salvage yard. Now the hard part is pressing the ball from the actuator arm back into the socket of the new clip. I found I needed a special pair of pliers that opened wide enough without requiring the handle to open too far. After it is snapped back in, you should be ready to put the door panel back on and hit the road.
Apr 28, 2009 | Buick Roadmaster Cars & Trucks
Locked out of vehicle Broke out sliding center section
Put the top part first, and the lift it until you can put the lower part in and lower it.
Mar 29, 2009 | 2005 Dodge Ram 2500 Truck
Broken sliding mechanism on HTC Mogul 6800
The same thing just happened to me, now one side is loose when i slide it, and the screen moves left, right, up, and down :(
Mar 22, 2009 | HTC PPC-6800 Smartphone
WIndow
If your window is off the track and sliding forward (leaving a gap at the rear) when you roll it down; the plastic guide that fits into the track is likely broken and very easy to replace. There should be a hole drilled into your at the top rear of the window where a plastic clip can snap in. Most auto part stores have these for sale or the dealer can be a last ditch alternative. Installation is a snap, literally (forgive the pun), roll your window half way down, you fold the clip over into the hole, snap it together and fit the window and the clip back in the the rail. Usually you can just grab hold of the top of the window and push the whole thing into the rail. Good Luck! Nick
Nov 08, 2008 | 1999 Pontiac Grand Am GT
Sliding drawer in the top refrigerator section
hi i have the 700tc as well,,ok the best way to place the drawer,,,extend the 2 sliders all the way out,,there is one pin at the end of each slider and 1 hole on each side of the drawer lip which lays on the track ,,,the holes on the drawer must fall into the pins otherwise it will not close,,,so place the drawer on top of the slider ,,,what usually happens is the sliders tend to roll back into the housing of the fridge,,,so while the drawer is resting on the sliders reach under the lip of the drawer and pull each slider until the the holes of the drawer falls into the pins,,,when the drawer is seated in the pins it will close smooth,,,hope this helps
Feb 10, 2008 | Sub-Zero 700TC Bottom Freezer Refrigerator
Slider popped out
Unless part of the plastic slide has broken off, you can simply "snap" it back in place. Being careful you my need to use a little force but it should just snap back into the track.
Dec 28, 2007 | Samsung SGH-D600 Cellular Phone
Oven door
I know on the older units it usually slides right back on. You might have to pinch the locking part of the hinge together, as it will have a spring that lets this happen. Once together, slide door onto hinge slowly. Too fast and it might slide past where it needs to go; if so, just pull back as if you are trying to remove for servicing. It should snap into place. Hope this helps. I might be able to tell you more if I knew the model#, type, etc.
Dec 23, 2007 | Jenn-Air JJW8130D Electric Single Oven
HTC TyTN II Smartphone Logo
41 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
