Question about Grundig G4000A FM/AM Radio
Speaker Wires I droped my radio down the stairs. The caseing was cracked but the radio still works. So in the process of super glueing the caseing to gather I pulled the speaker wires out of the radio, so now i have a radio that works exept it has no speakers. So my question is does anyone know where to reatach the speaker wires to the radio? Thanks
  • Grundig Master
  • 7,993 Answers
The wires that feed the speaker are usually attached on the back of the conical part of the speaker. They are usually soldered on two terminals.
Hope it helps.
Posted on Nov 09, 2009
BOse lifestyle 12 Series 2 Bass Module Front panel ratteling how to fix?
happy to help . well its a classic case of over tightnening the screws on the body of the speaker and then it cracks and the ratteling sounds starts coming or they r loose . just glue it down with super glue or tight them as required.
Nov 30, 2014 | Bose Audio Players & Recorders
DRIPS DURING STEAM PROCESS
Be sure no hairline cracks or pinhole in the steamer water container.
Put enough water level on it and not overfill it.
Repair hairline cracks or pinhole by applying epoxy or super glue in the surface.
Good luck.
Jun 28, 2011 | Rowenta Irons
I droped my 18 volt cordless B&D on the floor and
if it went to pieces when you dropped it, I'll just bet a manual won't help you, I'm thinking a case of super glue.
Jun 16, 2011 | Black & Decker 18 Volt Cordless Drill...
How to open and repair a short circuit inside the speaker
Probably, you'll need a Philips ("cross-head") screwdriver, to unscrew the front from the back of the speaker.
Or, it may be a "press-fit" (just try to "pull" the front from the back).
Or, it may be just glue holding the front to the back.
Slice through the glue, to "wedge" apart the two pieces.
Once open, probably, some solder, a wire-stripping tool, and a soldering-iron will be needed.
Jun 12, 2010 | Altec Lansing BXR1220 2 Speakers
Talkabout T5800 (22 Channels) 2-Way Radio: droped in water will not transmit but will receved...
Depending on the type of microphone used, if not the type using the speaker as a microphone, it may be damaged. I would though, suggest you remove the battery, open the case and allow the innards to dry in a warm place for several days. Even daily exposure to the sun should work fine.
May 16, 2010 | Motorola Talkabout T5800 (22 Channels)...
Subwoofer Speaker may need new cone
you cant get a new cone only a new speaker or you car repair it i used super glue on a crack in one of my old subs and it held well
Nov 06, 2008 | Rockford Fosgate Car Audio & Video
Good am
there are to areas in phone kinda a pain to find but one is keyed to be outside setting then you have the volume button key on side of phone took me a bit to find the outside loud feature in settings
its also quite possible you droped your phone and the speaker link got jared inside off its points this is somthing that is set in but not sodered in when they put these parts together it makes connection to base which is back plate to mother board inside phone i had a phone like this just had super glue speaker back down to front plate and it worked
but lets look at first setting its easier then opening up phone
May 09, 2008 | Motorola Mobility RAZR V3
Can't hear sound on one of the headphone's speaker
It's less common for one of the speakers to go bad in a set of headphones. It's possible - but there are more common problems that will cause this. I assume you have tried the headphones on another device to rule our a problem with the device you are currently listening with and using the other device, you still only hear audio from the left speaker.
The wires in the cord that connect the plug to the headphones are very thin and are susceptible to breaking. The most commmon place for these wires to break is at the point where the cord is flexed or stressed the most. Those points are:
1. Right at the plug
2. Where the wire enters into the left and right speaker.
There are occasions where I have seen the wires become unsoldered from the speaker terminals within the headphones themself.
What You Can Do:
1. While listening with the headphones, try flexing the cord back & forth at the plug and where the wire goes into the right speaker. See if the audio will come back and cut out again.
2. What I have done is cut the cord about 3" back from the plug. Go to Radio Shack and purchase a new plug and install a new plug on the cord.
3. You can also take the headphones apart and cut a few inches off the cord where it connects to the right speaker and reconnect the new end of the wire to the right speaker. The goal is to cut away the bad part of the cord and re-attach the good part back.
4. You can try to replace the entire cord but I haven't been able to find replacement (THIN) cords too easily.
Good Luck,
- Jim
Jan 24, 2008 | Radio Communications
Deck is powering off every 5 seconds
If radio stays on at low or no volume and cuts out when turning up you may have your battery backup voltage (yellow wire) droping below 10v under signal load. There is a circuit called backup check in radio that moniters Voltage It may seem ok when measuring without volume but under load it will fluctuate with the audio. Try hooking up Heavy guage Ground and Backup battery wires to prevent voltage loss across wires under load. Also check for any speaker that may not be producing proper sound when and if you can get radio working Disconnect wires to that speaker to see if radio will stay on. Just a couple of many possibilities.
kstahl65@att.net
Jan 12, 2008 | JVC KD-S890 CD Player
Grundig G4000A FM/AM Radio Logo
110 people viewed this question
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
