1. If you have downloaded all the updates for this model router and it still will not connect it may be due to "incompatibility withe Macbook Pro or the what is call end of life" for this device and a new router will probably work better.
I would check D-Link's page for update for your model
2. check to see if your setting for TCP/IP is correct
( that is that you don't have the ip ( internet protocol ) set to a static IP that is a set IP.
3. Check to see if you have you setting for DHCP ( automatically) this will allow the server to set an ip or the the router.
Most routers that have there settings for static are a special setup.
