Question about Alpine CDA-9851 CD Player
Ipod connection instruction
I would like to know if there is any way to connect ipod directly to the cda-9851 alpine headunit and how .
Greenpear190,
 Unfortunately, you have to have a special adapter (actually 2).  One plugs into the Ai-Net port on the back of your receiver.  This is the Alpine KCA-121B adapter.  It provides two female RCA plugs in which you will have to have a 3.5mm plug-to-2 male RCA plug coming out of your iPod to plug into the two female RCA plugs that the Ai-Net adapter offers.  Then you are set to go.  The Alpine adapter can be found at www.crutchfield.com or surely BestBuy could order it if not already in stock.  The 3.5mm plug on the rear of the receiver is actually for a steering-wheel remote control setup, fyi.  The Alpine adapter is required.
Posted on Sep 08, 2008
    Problem Solver:
  • 13 Answers
You can get a set of phono leads with a jack on just one end?plug that in to the back of the head unit (depending on your pre out options and aux option) then plug it straight in to you ipod.
hope that helps?
Posted on Mar 08, 2008
Hook up an ipod to this stereo
Get the Alpine KCA 420i adapter. I've had it for about 3 years and no problems. You can install the module anywhere and run the wire for the ipod just about anywhere. You can go through all of your ipod folders on the headunit. However, you will find out quickly that it can be a pain using the Alpine headunit interface tiresome on the CDA 9830 model and others similar from a few years back. I don't know if other head units have solved this issue.
Jul 16, 2009 | Alpine CDA-9830 CD Player
Ipod control?
You can purchase the KCA-420i and connect it to to the ai-net port behind the headunit. This will allow you to send signal from your ipod to your alpine headunit while still retaining your operating functions to the ipod. Can be purchased for about 10 bucks on ebay.
May 21, 2009 | Alpine CDA-9887 CD Player
Connecting mp3 player other than ipod to cda 9851
CLICK HERE for your owners manual in PDF format.
Please see Page 19 on how to toggle ON the AUX IN function on the radio
A KCA-121B (alpine bus to RCA) adapter is required.
-or-
AI-3NPUT (alpine bus to Female 3.5mm) adapter is required.
There is no alternate INPUT on the rear of this radio - an adapter is required... converting the changer port to an input.
Thanks for using FixYA - a FixYa rating is appreciated for answering your FREE question.
May 12, 2009 | Alpine CDA-9851 CD Player
Cd player won't open
Try disconnecting the car battery for a few minutes, the unit may reset when you re-connect the battery. Worth a try.
Nov 20, 2008 | Alpine CDA-9851 CD Player
IPOD hook up?
you need to purchase (if you do not have it already) the KCA-420i Alpine Interface Adapter for iPod (item # 500KCA420i). and connect it to the aux input socket
Oct 07, 2008 | Alpine CDA-9851 CD Player
Playing external sources
you have to switch your decks source to AUX and it should work fine. If not you may have a bum player with a bad input.
Jan 22, 2008 | Alpine CDA-9851 CD Player
Peripheral's Connex2Car adapter to an Alpine CDA-9851
the alpine should recognize it as a "changer" when you select the source; ie: radio, CD, changer. Sounds simple, but have you turned up the volume on the iPod?
The Alpine adapter is $100, but works great, you can totally control all your iPods functions, and it displays all song info on the Alpine decks display.
Dec 30, 2007 | Alpine CDA-9851 CD Player
How to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Aug 21, 2007 | Alpine CDA-9851 CD Player
Alpine CDA-9851 (turning off and back on)
If someone tried to steal it maybe they Jolted some of the wires behind the harness or the connection into the harness and when you are driving it loses its connectivity. Check all of the connections in the harness and make sure noone of them feel loose. Just as a test try putting it in another car(if applicable) or bench test it, I.e leave it hooked up directly to the battery for a while playing a cd with a small speaker hooked up to a channel( make sure wires dont cross...!!!!!!) and see if you can replicate the issue. Just some thoughts.
Feb 13, 2007 | Alpine CDA-9851 CD Player
Alpine CDA-9851 CD Player Logo
295 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
