The picture on bottom 1/3rd of screen is bowed up and Strong Red then Green shadows upwards 1/2 way up screen to almost normal picture on top 1/2 to 1/3rd of screen
i have the same problem. did this fix yours? i was told you had to manually converge after installing the ic's is that true? and how do you do that? i was told by a repair man its very expensive, 2-3 hours @225$ an hour.i have the same problem. did this fix yours? i was told you had to manually converge after installing the ic's is that true? and how do you do that? i was told by a repair man its very expensive, 2-3 hours @225$ an hour.
You can't post conmments that contain an email address.
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
I just replaced the 2 convergance chips, but it did not seem to fix the problem. I then tested all the resistors that feed the convergence chips anf there was a 2.2 ohm fusable blown. IT was R7050 on mine. That seemed to fix it so that I could adjust all the colors through the convergence 2 screen. There seems to be a slight bow near the bottom when you look at the c2 screen, but not noticable when you are watching a picture. Since I got this broken, I am not sure how perfect it should be.
If anyone can send me the service manual, I would appretiate it. Thanks.
