I have a vaio vgn tx790 and i was trying to change the screen, when i took the screen out and left the screen wire loose, the laptop light came on and off and since then it wont turnback on, no power at all
  • maldeekmike Mar 09, 2008
    thx much, but i was trying to dismantle the laptop and it seems that it stock right in the middle although i unscrewed all screws, shouldnt get loose easy or what is there a clip in the middle, iam confused,,,thx a lot
  • j131 May 11, 2010
    MaldeeMike just wondering if you ever got this problem solved as I have EXACTLY the same problem. Thanks,
  • 520 Answers
You have had power in pc and wire have touched/connected to something they shoundnt of and shorted.
you could of looked at a service manual first which would of clearly stated remove power cable and battery first and ground to discharge any static.
if youre lucky you may get it to start.try startup with first only power cable(battery not connected) Then battery only connected.if not work power on circuit on motherboard blown,probably transistor easy to repair but not for the novice.
Posted on Mar 08, 2008
  • tat4u
    tat4u Mar 09, 2008
    cant say for the sony vaio never had to dismantle screen.If it was in front of me no doubt I could sort it ;as Ive never needed to use a service manual ever,but Ive been repairing laptops for years so have a lot of experience.
    It would really help you if u was to get a service manual then u could check the precedure for dismantle.
My laptop screen is not full screen sony vaio
Go to start menu, control panel, click display, and click setting at top right, left side down you will see a arrow under resolution, move mouse over it and move it one notch to the left, click apply, and a small window will pop up, do you want save these changes, click ok. Repeat if needed.
Mar 23, 2012 | Sony VAIO VGN-AR870NB Notebook
After xp installation my sony vaio vgn-sz2xp display did not appearfully.black spaces are appeared on the both side of the screen......... kindly help me its too urjent
I would guess that the video driver has not been installed? If it has, try changing the display resolution to see if it will fill the screen.
You can obtain driver software for this machine at the following URL:
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-SZ2XP_C
Jul 22, 2011 | Sony VAIO® VGN-SZ2XP PC Notebook
I have a sony VGN-FE890 and I took it out from my luggage this morning and the screen is messed up. I can still see stuffs but the brighness is so low. I tried to adjust the brightness, but it's not...
Many times this is an inverter issue or a wire that is pinched. Check to see if moving the screen forward or backword gives you better brightness. however, many times this is just a setting.
You can try using the FN key located on the keyboard lower left side. Hold that down and press the function Key (f1-f12) that shows a picture of a SUN and a Plus sign. Now this can also be on the Arrow keys (depends on the keyboard).
If that doesn't work you will have to take it in.
Jul 10, 2011 | Sony VAIO VGN-FE890 Laptop
I dropped my laptop, Vaio VGN-NR185E, and the screen is turning blue with the white colors, so if there's a blank page it's blue instead of white, I believe it's the inverter or maybe a loose wire, What do...
If the unit was dropped, it could be that a wire /cable came loose,but it most likely is the LCD screen. Was the unit dropped on one edge of the unit or did it land flat?
on edge: probably the LCD screen
flat: loose cable or inverter
Best guess....without seeing unit.
Nov 15, 2010 | Sony VGN-NR185E/S VAIO NR Series
Dark Screen
Sounds like you broke your backlight and need a new LCD screen. A new one can be found here for $70.
http://cgi.ebay.com/SONY-VAIO-VGN-SZ1-B-VGN-SZ110-LCD-SCREEN-13-3-WXGA_W0QQitemZ350247988452QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item518c682ce4
Mar 15, 2010 | Sony VAIO VGN-SZ110/B Notebook
Changing the LED Screen on a Sony Vaio VGN FW21L Laptop
Do a search on youtube. I've seen many computer repair videos there
Mar 11, 2010 | Computers & Internet
The power light is showing but the hard drive light is not
Try reseating the hard drive and trying. Maybe the wire might have gone loose.
Mar 07, 2010 | Sony VAIO VGN-NS135E/S Notebook PC
VAio VGN-FS742 Screen does not display
Try to remove the battery, remove AC adapter, and press and hold power button for 45 sec. reinsert battery, and Plug and try again, if that doesn't solve it, you may need to try to change memory first, (cheapest) or the motherboard or CPU.
Please give good rating if this helps your issue, Thanks
Apr 12, 2009 | Sony VAIO VGN-FS742/W Notebook
Were do you find the switch for the wireless on these laptops
It all depends on the Make / Model. Some are physical (hardware) switches and some are software.
VAIO (General) - Switch on front left
VAIO (General, not further identified) - Button (or slide switch) on the Front Left or Right side
VAIO - VGW-AW125T - Button on Front Left, below keyboard
VAIO - VGN-AX570G - Button on Front Left
VAIO - VGN-B2560 - On top left of Keyboard (light say's wireless when on)
Feb 27, 2009 | Computers & Internet
LIGHT BLUE VERTICAL LINE ON MONITOR
The vertical line is a bad pixel sensor at the edge of the screen, your screen has hundreds of vertical and horizonal pixel sensors. This is an indicator that the screen is going out and need replacing.
Jul 03, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Computers & Internet Logo
David Payne
David Payne
