Question about Mitsubishi VS-50707 50" Rear Projection Television
Mitsubishi VS-50707 50 in. Rear Projection...
The T.V. has a lines across the top. The color doesn't seem right, it seems to be dark and a little foggy. When watching the t.v. it will get all distorted and have black lines rolling throught the lower half horizontally. If you hit PIP on the remote the whole screen is full of lines and jumping. You need to unplug the t.v. and plug it back in to watch it again. Could it be the PIP board? If so how do you bypass?
  • Mitsubishi Master
  • 8,617 Answers
There is a quick test you can do to determine if the problem is in your PIP module, using two 4.7uf/50v electrolytic capacitors. The PIP module plugs into two connectors on the main board. Remove the PIP module, and on connector VP on the main board (the 11 pin connector), use one cap to jumper from pin 7 to 9 (negative lead on pin 9); and use the other cap to jumper from pin 5 to 11 (negative lead on pin 11). If the PIP module is bad, you will now have video. The PIP module has surface mount capacitors that go bad. Just make sure you solder a small lentgh of wire to the capacitor leads to prevent them from shorting as they cross over each other. Just plug the wires into the socket no need to solder them.
Posted on Mar 08, 2008
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Lines in picture
can you post a picture of the lines that are going across your screen? Sounds like maybe retrace lines.
Feb 14, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs-60803
greetings from belize take your set to a tech and have him look at it.good luck.
Mar 23, 2007 | Mitsubishi VS-60803 60" Rear Projection...
Mitsubishi 50" VS 50605
we need to know if the lines are of different colors or are they white and the screen is too bright ?, 275.00 seems a lot just to get it check out but it all depends were you are,in NY that could be a going charge but in pittsburgh it seems too much,please let us know what the lines look like.
Oct 09, 2006 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50707 50" Rear Projection Television Logo
141 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
