Question about ViewSonic N3250W Television
I need to find a new circuit board for my Viewsonic N3250W monitor. It stopped turning on a week ago and I opened it up and found 2 x circuit boards. They look easy enough to change out and I was wondering where I could buy them.I believe that I could change them out cheaper than finding an authorized repair tech. If this doesn't work then I don't know.
  • oldjeff May 11, 2010
    I have the same problem. Did changing the board from viewsonic solve?
    Problem Solver:
  • 6 Answers
I got the same tv from a friend with the same problem. He didn't want to fix it so I decided to give it a shot. I've done a bit of research and happened to find an individual with way more smarts than I have in the matter, but he did put up some links to replacement power supply cards that aren't through viewsonic so they are in stock as of today and other possible fixes. The cards are a little more expensive, but you can order them now and there's an alternate card that may be more reliable. My particular case has a burnt-out chip that I ordered, so we'll see how that goes. All the credit goes to this guy, here's his link...
http://pagesperso-orange.fr/alain.mionnet/enii3210j.htm
Posted on Jun 26, 2008
  • gboy77 Aug 06, 2008
    just wanted to follow up and say that the small chip fixed the problem. I ordered it for $20 and soldered it in. the tv is working fine a month later.
I have the same model and same problem. i found a listing for a control board at the viewsonic online store. here is the link:
http://store.viewsonic.com/html/ibeCCtpItmDspRte.jsp?a=b&item=122065
i also called viewsonic parts at 1-888-881-8781, and they said they still make parts for this model.
Posted on Apr 09, 2008
Viewsonic N3250w. Power supply went out and I replaced the bad capacitors. TV worked for a week then now when I turn it on, the screen just turns on and off
Check to see if the 24vdc disappear when the screen black out, it is always there then you have problem in the backlight inverter board. Did you replace the caps in the 24vdc supply also? I replace the whole set.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20N3250W/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for yo
Sep 05, 2010 | ViewSonic N3250W Television
Hi there, My Viewsonic failed about a year ago and I'm hoping to bring it back to life Problem: It won't turn on. Observations (thus far): Green light visible on AC Adapter, as well as on Logic Board Caps...
Buy a new monitor!! Seriously, unless you're the techie type that likes to tear open electronic equipment to see how it works and/or fix it, you're better off buying a new monitor especially if this old monitor of your's is a LCD.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Mar 11, 2010 | ViewSonic VA550 15" Flat Panel LCD Monitor
N3250W is turning on and off every 5-10 seconds. I have cycled power with no change.
HI MY NAME IS SALVATORE YOU PROBLEM IS IN THE INVERTER TARGET ONE TRNSFORMER IS BAD CHECK IMPEDANCE U HAVE 8 TRANSFORMERS ONE OF THOSE IS BAD,I NEED OF U...I BROKE A CONECTOR IS OF MOTHER BOARD TO TARGET OF VIDEO PROCESOR I LOSS HOW CAN I CONECT IF U CAN SEND ME A PHOTO...TANKS I APRECIATE my mail dar-75@hotmail.com sorry im spanish
Feb 13, 2010 | ViewSonic N3250W Television
Viewsonic N3250W I replaced the power supply board but when I turn on, the screen flashes real quick and there is no picture.
it was not the power supply its the invertor board that controls the back lighting/switch on screen flashes lights go off/shine torch into screen ull see picture/get new invertor board 7 or 8 little plugs go into it
part or repairs in uk ohm supplies
Jan 08, 2010 | ViewSonic N3250W Television
ViewSonic N3250w
The defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Turns OFF by itself.
Needs to be unplug to make it work.
Works for a few minutes then turns OFF.
I repair these power supplies, if you need further assistance jah2mil@hotmail.com
Aug 22, 2009 | ViewSonic N3250W Television
No picture on N3250W viewsonic
I just had a viewsonic supply all apart with a blown capacitor, I believe c36. q7 a surface mount npn transistor on the solder side of board was shorted. Replaced cap and transistor, set works fine. Also, check all your electrolytics on this board as they sometimes swell and go bad.
Jan 07, 2009 | ViewSonic N3250W Television
ViewSonic N3250W will not turn on
check out this website:
I got one of these tvs from a co-worker who didn't want to try to fix it. I stumbled across this brilliant person's work and ordered the small chip from a place in san fran. it was here in 3 days, i carefully soldered in the new chip (not at all easy, be careful not to pull up the contacts on the circuit board when you remove the burnt one) and the tv has been working fine ever since. only $20 with shipping.
Jul 03, 2008 | ViewSonic N3250W Television
N3250w fix
i didn't get a new board, but replaced the chip as described at the end of this website. tv is working fine.
check it out. if you want to replace the board, he has listed suppliers for that as well.
May 19, 2008 | ViewSonic N3250W Television
Televison & Video Logo
94 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
