Question about Kitchen Ranges
Viking downdraft stove ventilator does not turn on
  • 3 more comments
  • pbousum Mar 08, 2008
    48 inch downdraft viking. stopped turning on in spite of pushing switch on right side. tried different power source (outlets) and no change.
    nothing stuck and power source ok
    double check??
    it is a 48 inch viking downdraft fitted behind a 6 burner gas desktop
    the vent is independent from the range. when you turn it one it raises out of the counter and drafts at the selected strength. It now does nothing when you press the on button.
    Brigadier General:
  • Kitchen Ranges Master
  • 3,614 Answers
Can you provide me some info on how/s the operation now of your unit, does it still running though the problem in there?
thanks,
Posted on Mar 08, 2008
  • 1 more comment
  • micromaster
    micromaster Mar 08, 2008
    have you done some double check on the unit?
  • micromaster
    Most likely it is a problem with the fan motor. It suppose to come to have a shorted lines to your range and looks like one of them is missing. The best option is service it to a repairman to check both the oven and the powerto the ventillations...post back
  • micromaster
    an electrical shortage on the unit, check it with an electrician to check and repair any cut or burn wires that cause for not starting the unit due to not having electrical supply on it.
  • 871 Answers
Hey there
kindly check the chimney assembly if there are anything stuck there. if not, check also the connection of the wiring if it is correctly plugged to the assigned voltage.
if i may ask, what exact type of ventilator are you using? because there are already designer types on the market today...
  • earl norman llanera
    earl norman llanera Mar 09, 2008
    could it possibly the switch itself is faulty? have tried opening the switch housing to determine if there is something wrong with the switch itself.
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Power at the plug, no response from "on/off" button.
Follow the power line with a tester, see where it is interrupted
Sep 16, 2015 | Viking VIPR162 36" Downdraft Ventilation...
Downdraft ventilator has stopped working
We have a Viking VIPR101 30" downdraft ventilator. We've learned that the ON-OFF switch on the side of the ventilator can overheat and burn out when it is held down continuously (poor design). Best to push and quickly release it. First time we had the switch professionally replaced--it's modular and very simple to swap out. Next time we fixed it ourselves with switch part # PV300182 from allvikingparts.com. They had replacement guidance on-line. Hope this is useful.
Mar 17, 2015 | Viking VGRT360-6B 36 in. Gas Cooktop
I have a wolf dd36i downdraft cook top ventilator just stopped working it has power and the switch is conected to the remot e
WOLF DD36I USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Wolf Manuals > Cooktop > DD36I
View and Download Wolf DD36I user manual online. ... cooktop. Wolf downdraft ventilation systems are recommended. for use with Wolf electric ... The downdraft will operate most efficiently when ductwork does not exceed 40' (12 m) in length.
Feb 16, 2012 | Viking VIPR101 Kitchen Hood
No gas on viking professional. ignitor works downdraft does not
There are solenoids that turn the gas on to a burner. If they're bad it won't supply gas to the burner. There is also a mother board on that model that could also be the problem. When it comes to this brand it's difficult to diagnose without being there. If the downdraft is not working then I would guess that the mother board could be the problem...sorry I couldn't help more.
Aug 27, 2011 | Viking 37 in. VGSU163-6B Gas Cooktop
I would like to put my cook top on an island in the centre of my kitchen how would i vent down thru a crawl space???
Get a downdraft cook top and drill a hole. Then run the piping to the outside wall of the house and drill again and run the piping thru to the outside. They make outside wall vents like dryer vents only bigger to accommodate the bigger vent pipe. Happy crawling. It will look and work great if you get a good stove. Do your research.
Sep 01, 2010 | Electrolux Icon Downdraft Ventilation...
My Viking VIPR101 Downdraft Ventilator is not working.
It's fixable, but it is easier for them to just sell you the whole expensive part. See the problem and solution at:
http://www.fixya.com/support/t410261-viking_downdraft_ventilator_electrical
Jun 04, 2009 | Viking VIPR101 Kitchen Hood
Viking downdraft ventilator electrical problem.
You seem to have a slightly different model, but see a solution at:
it is probably the same thing
May 28, 2009 | Viking VIPR101 Kitchen Hood
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
Kitchen Ranges Logo
117 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
