Question about Dishwashers
Delonghi dishwasher E1
Hi, I have a Delonghi dishwasher - ST9AU and I'm getting E1 on the screen. The dishwasher will not finish it's cycle and it has just started to leak water. Can you please tell me what this code means and how I can fix it? Thanks, Regards, Steve
  • Anonymous Apr 27, 2008
    dish washer wont finish cycle and then comes up with E1
  • 183 Answers
SOURCE: shu9915uc dishwasher wont drain
it should have water just below filter tray, if it does not actually empty then you have a blockage ,remove left side panel to gain access to drain pipe and side chamber. Regards Engineer
Posted on Aug 05, 2007
  • 905 Answers
SOURCE: Delonghi Dishwasher
this is a water inlet problem , not enough water coming in, so the pressure is low going into or thru the dishwasher , check for clogged inlets
Posted on Oct 26, 2008
  • 210 Answers
SOURCE: LG LD-A2T2 Dishwasher returns Error code E1
EI is an error to do with your drain. Check your drain hook up. You should have a loop out side the unit, it should be a minimum 40in in height, or put in a air break. What I believe is happening is your unit is siphoning out. Fix this and you will be able to stop washing the dishes by hand.
Sgt 48
Posted on Jun 19, 2008
rickzilla
  • 706 Answers
SOURCE: LG LD-14AW3 Dishwasher leaking after cycle
Sounds like you've diagnosed the solution on your own.. Most of the inlet valves are spring loaded so that if power is removed or disabled.. it defaults to a closed state and doesn't allow water int the wash basin. To open, they need to be energized by the control system so you may have one of two issues.. a faulty inlet valve that doesn't spring closed when it is not energized or a controller that is comanding that valve to open ( less likely of the two) For a quick test.. make sure the DW is dry inside and open the door. wait and watch for water to enter the basin.. If it does begin to fill up.. your inlet valve could be the root of your problem.. It is also possible that you are back-siphoning waste water in from the drain system. If the water looks dirty then that is more than likely the problem so you may have a clogged pump, kinked drain hose or your drain system itself is not draining as fast as the DW pump forces the water out.
You should routinely clean the pump filter so that the pump can remove all the wash water without having to draw it thru food debris caught in the filter.. Hope someof these ideas will help you solve your problem..
Posted on Sep 01, 2008
  • 40 Answers
SOURCE: Electrolux dishwasher leaking steam when
Steam is normal, its getting rid of the mosture inside the dishwasher.
Posted on Sep 15, 2008
Hi. Can you tell me what E1 means on the display
LG Dishwasher Error Code E1 How To Clear
Based on your model number ... it is probably an LG appliance.
Use the link above to learn about the E1 error code. According to the web site ... there is a chance that nothing is broken and the code may have been caused by how the dishwasher was loaded. The web site lists 7 reasons why the E1 code came on.
Helpful?
Good luck with your troubleshooting
Jan 25, 2018 | Dishwashers
Delonghi Dishwasher
Can you please tell us the exact model of your dishwasher? What you can try initially is unplug the power cable of your unit for about 10 minutes, then plug it back in. See if that clears the error. Will give you follow up about the E1 error.
Oct 26, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwasher not cleaning dishes
hi paula.
Insufficient water in the dishwasher also can cause poorcleaning. If the float gets stuck in the raised position, thedishwasher won't fill with water (Photo 3). Another likely cause is a clogged inlet screen or faulty inlet valve. ... To determine if your dishwasher is getting enough water, start a wash cycle.
Dishwasher Repair Tips: Dishwasher Not Cleaning Dishes ' Family ...
https://www.familyhandyman.com/.../dishwasher.../dishwasher...dishwasher-not-cleaning...
Dishwasher not cleaning dishes Google Search
Nov 02, 2017 | Dishwashers
How to fix a dishwasher that will not drain!
good to know the cleaning procedure worked for you. You can also get good results by using Finish dishwasher cleaning kit available from supermarket and running dishwasher empty with it once in 3-4 months. Keeps dishwasher clean and free of draining problems.
Apr 14, 2014 | Dishwashers
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
Hi Kenwood dishwasher kdw60x10 - runs cycle then stops showing error E1 - still full of water.
I have the same problem :( e1 fault and full of water, I have check pressure and drain for blockages too.
May 14, 2011 | Dishwashers
"E1" problem
I would request you to please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Hope this helps resolve the issue.
God Bless
Jul 09, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
E 1 error
90% of the time you get an E1 error code is because the drain hose is not properly installed between the LG dishwasher and the drain. The hose should connect to an Air Gap valve (almost free at any hardware store) but in a pinch, raise the drain hose near the drain and attach the hose to the bottom of the counter top under the sink. Is should rise almost 30 inches between the dishwasher and the drain or the water WILL siphon out of the dishwasher as soon as the wash or rinse cycle begins (and take 5 minutes before the water gets low enough the cause the E1 error.
Good Luck!
Nov 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
I have error code e1
Hi. Sorry this is so late, but I just happened across this post, so I thought I'd see if you have solved your problem yet. The EI code most often is caused by water leaving the tub during the wash cycle. The most common cause of this is that the dishwasher drain hose does not have a high loop in it. Often, the installer ran the hose right down through the floor. It needs to loop up high before going to the drain to prevent water loss, and a resulting IE code.
Oct 25, 2008 | LG LDF6810 Built-in Dishwasher
Error codes
Usally this is a bad control board or in some cases, a bad display board. they are fairly easy to replace and should be covered under a 5 year parts warranty (no labor). if its older than 5 years i would advise getting rid of it before putting any real money into it as Eurotechs are affectionatly know as Eurotrash in the industry and it WILL give you more problems. If you need a short dishwasher to fit under some shorter than standard counters, go with an ASKO. They are made by the same parent company, but are 50 times better. Good luck!
May 26, 2007 | EuroTech 24 in. EDW194E Built-in...
Dishwashers Logo
2,729 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
