Question about Briel Versatile 112924 Espresso Machine
Replacing o ring for steam wand
I am really ashamed to say that I am stumped by how to get to the innards of the Briel Versatile Due to replace the o ring between the steam wand and the plastic housing. According to the schematic I was sent, I have to lift off the plate warmer (done) and unscrew the cover - apparently there is a screw under a rubber cover next to the spoon. I have prised out a rubber stopper and a long way down there is something that may or may not be a screw. Am I being dim??
  • 32 Answers
You can purchase any Briel part you need in the U.S. at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
ph 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 10, 2008
    Novelist:
  • 135 Answers
Not dim, though you may need to find a long screwdriver.
I've already disassembled my machine, which is the ES37S model. Yes, you remove the rubber stopper. Then you take a long and skinny screwdriver and remove the phillips-head screw at the bottom of that hole. With that screw removed, the entire plastic top of the machine comes off.
I still need to find the milk-steamer knob, which is broken on mine, so I'm in search of a parts distributor. If you have any idea where I can find Briel parts in the US, I would appreciate any contact info you may have. Thank you. ;)
Posted on May 27, 2008
I haven't used my briel versatile due coffee machine in ages and now it won't work. What can I do?
Difference in a lime problem is not on the brand of the machine but the time of inactivity has priority here little suggestions about.
Descale your Espresso Machine Before it too late Should You Descale with Vinegar
Jun 20, 2015 | Briel Coffee Makers & Espresso Machines
Ascaso Dream
If your steam wand is leaking then you may need to replace steam wand o rings. These can be found at Ascaso gasket kit Dream Arc Basic . Available in a kit with easy to follow instructions.
Try Dream Arc Basic Ellipse 150 Products
Feb 16, 2014 | Ascaso Dream Espresso Machine
Delonghi Magnifica My steam arm drips when I make coffee.
I initially replaced the o-rings in the pipe/valve assembly. It didn't work for long (not correct size o-rings probably). I then bought a new pipe-valve unit. To replace you need to pry off the stream handle (chromed plastic). It only fits one way on the axle (so take notice when replacing!). Then remove back and side covers (6 screws all at the back). Then remove top (2 screws each side at the front and a couple at the back). Then the front panel should be lose. (Instructions based on a slightly different model)
Mine made better coffee after I fixed the leak! A large portion (perhaps 25%) of the water intended for the coffee went via the steam wand straight into the drip tray, which is not good.
Oct 15, 2012 | DeLonghi Magnifica 3300 Espresso Machine
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
Cant make hot milk or foam ascaso dream the wand doesnt work it just stopped. also my coffee is not hot, only lukewarm ive opened it up and everything looks ok, its all just electrics all of which look...
Hi Mike,
You may have 2 issues.
Steam wand may be blocked;
Try descaling the machine 1st before you do any thing else.
1.Try removing the steam tip, if you don't get steam with tip removed, try removing wand, if you don't get steam then the steam pin may be blocked.
If after descaling coffee is still jst warm you could replace thermostats http://www.bluestarcoffee.eu/ascaso--boiler-thermostats-x-2-193-p.asp
If you still don't have steam after descaling and replacing thermostats then you may need to replace the o rings on steam pin.
http://www.bluestarcoffee.eu/ascaso-gasket-kit-dream-arc-basic-114-p.asp
Ascaso descale sachets 10
Mar 31, 2011 | Ascaso Dream Espresso Machine
I have a Briel ED 132A Classic how do I prime the pump for the st
Sometimes the self- priming pump feature may not work due to a momentary "air lock" condition. If water does not flow from brew head, place a cup under the steam frother. Open steam control and turn the switcher onto the icon of the half-full cup until water flows from steam frother. Turn off steam control, as Espresso maker is now ready.
Manual is located here:
http://www.smithagy.net/BrielInstructionManual.pdf
Mar 15, 2009 | Briel Sintra ED-132 Espresso & Coffee...
Water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Dec 07, 2008 | Rancilio Silvia Espresso Machine
Spares for Briel Coffee Machine
You can obtain any part at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Nov 12, 2008 | Briel Domus Due Espresso Machine & Coffee...
Briel Versatile Due Coffee Machine
You can get it at the Briel service/distribution center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Sep 05, 2008 | Briel Domus Due Espresso Machine & Coffee...
Briel Versatile 112924 Espresso Machine Logo
463 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Dennis Fitzsimmons
Level 1 Expert
Tom Chichester
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
