Question about Philips Magnavox 27MS343S 27" TV
Magnavox tv problem
I have a 2 year old Magnavox tv and 3 days ago the sound stopped working while I was watching it so I turned it of and then back on and now there is just a line, channel number, and the word mono on the screen. I went in and all my settings were at 0 so I changed them and then once I tried to go to a channel every thing erased. I think I need a new one but I thought I would double check and make sure that I am not forgetting something...Thanks, Cindy
  • Cyndy321 Mar 08, 2008
    There is are pencil thin lines about an inch from the top of the screen. Red, yellow, then blue...
    Scholar:
  • 52 Answers
Describe the "line" for me. Is it horizontal or vertical and how long is it and how wide (or thick) is it? Keever
Posted on Mar 08, 2008
  • mack paulk Mar 09, 2008
    You've got a tough problem for me. I have seen similar lines before and the problem was a capacitor in the Horizontal deflection circuits, but this should not affect your sound. You might have a power supply problem since both audio and video are effected. Without some experience and a schematic, you will have a hard time with this one I am thinking. But I have been wrong a thousand times, so maybe you will be lucky and someone else with more experience than me can help you.
    Wish I could have helped.
    Keever
42'' Magnavox 42MF231D/17 with picture/sound problem
Hi my name is Roety,
I can help you with your issue ,
Sounds like a bad SSB small signal board
login as a guest and check price and availability at
encompass.com
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 31, 2009 | Philips Magnavox 42MF521D/37 Television
Magnavox 20mt4405/17 piece of junk!
Hello sletak, This problem is actually common. Your degaussing coil has malfunctioned, causing the power supply to become unstable which in trun is effecting the memory settings in the processor. You have threen problems in one so lets start by looking at the overall cause first 1) degaussing coil going bad (shorted then opened) Replace this and the thermistor that is attached to the degaussing circuitry. 2) power supply instability (power surge from the degaussing circuit) replace the damaged components in the power supply section. Troubleshoot this thoroughly. 3) after fixing the power supply and the degaussing components you will need to manually degauss the TV and then use the auto-degaussing function to do the rest. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 10, 2009 | Philips Magnavox 20MS233S 20" TV
Ok my Magnavox digitla converter box has been
Something is wrong with the box, you most likely will need a new one.
Jun 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Feb 19, 2009 | Philips Magnavox 27MS343S 27" TV
Dvd freezes
If less than a year old, this TV is likely under warranty but should have been taken back immediately to address the issue. I suggest contacting the vendor or manufacturer.
Jan 04, 2018 | Philips Magnavox 27MS343S 27" TV
Magnavox 55
Sounds to me like you need a new control panel board which should run you about $150-$200 max! might be semi burnt out like mine was and that is what i had to pay not sure if this helps but hey ya never know :)
Sep 08, 2008 | Philips Magnavox 55P9271 55" Rear...
Magnavox 50" plasma Won't Power on/Shut's off/Blinking red LED
The above fix, listed by Tom saved us!! We did as instructed and took off the back of our 50 inch Magnavox plasma tv. We were not sure what we were looking for so we googled capacitator (image) & there was a photo of a fried capacitator! Sure enough we noticed ours were "fried", we took out the board and went to an electronic supply store, bought the 2 capacitators ($2.00 each!!) and then found someone who did tv repair to sauter the new capacitators onto the board. (It is important someone who know how to sauter and recognizes polarity do do this for you) All in all we fixed this following the above instructions for $34.00 and our time. For a month we were told to spend hundreds getting a new power board!
Kudos to you Tom & thanks so much!!
May 14, 2008 | Televison & Video
27 in Magnavox Smart TV
problem in vertical circuit 100uf 35 volt cap also could have poor solder connections on vertical ic
May 02, 2008 | Philips Magnavox 20MS233S 20" TV
No sound-power switch on T.V. flashing 9 times
May be a bad optoIC. Goto www.magnavoxhelp.com to see if they have a repair kit for your model.
Oct 05, 2006 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 27MS343S 27" TV Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
