I am getting a "colour negative" at the bottom of some of the pictures in my file while I am working on other pictures. Any ideas?
    Sergeant:
    Champion:
  • 326 Answers
U may have taken the pics as negatives and put them there unknowing or they may be a product of the pic program u r using. If they bother u, delete them and if not, ignore them.
Posted on Mar 15, 2008
It might b the problem of virus. or it cn b also problem with monitor or the mother board problem so plz consult a computer hardware person and let him check it.
Posted on Mar 13, 2008
Plz dont opev the hard drive. if u r not having the proper instruments. coz it contains a vaccume in it , it contains platers n a read and a wright head. this may get dammaged an the dive may get a problem forever. so u plz go n contack to an authorized person only.
thankyou
Picture is blurred like in negative and has excess colour
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 17, 2015 | Televison & Video
Tip
Cathode emission check for colour picture tubes
<p>How to check the colour cathodes of a picture tube for emission<br /> <p> <br> <p>It is very easy to cehck the emission of the cathodes of a colour picture tube. Assuming all other circuit parts are working, including LOT [Line output Transformer] and video output section.<span> </SPAN>There is proper screen voltage; focus voltage and EHT [Extra High Tension]. Locate the three cathode points on the base card, usually marked as Gk, Bk and Rk.<span> </SPAN>Keep the brightness, contrast and colour control to zero position.<span> </SPAN>Take a wire of suitable length, say 50cms or so, tie its one end to TVs chasis [negative].<span> </SPAN>Take one resistor of value 100K 1W, tie its one end to the other end or the wire, thus one end of this resistor is now connected to negative chasis and the other end of it is free now.<span> </SPAN>Hold this resistor with with some electrically noncunductive material [using hand gloves will be better]; switch on the Tv, wait a minute or so to get it warm up.<span> </SPAN>Just make a touch at each cathode of the picture tube base card solderings.<span> </SPAN>Just one touch will give you a colour of the respecive cathode on the screen.<span> </SPAN>Never hold it for long time. This process can be used for checking cathode emission of any type of Cathode Ray Picture tubes. <br> <p>
on Apr 18, 2011 | Televison & Video
Won't print in color. Looks like a negative
Try going to printer settings either via 'file' 'print' or 'start' 'control panel' 'printers'
some printers have settings colour - text - photo - gray scale - chrome - negative etc Click on the one you need & 'save'
Alternatively, if the print has some colour but lacks others you may be out of ink/toner of the missing colour[s]
Dec 23, 2009 | Dell 3100cn Laser Printer
Picture suddendly changed to &quot;photo
hi! your lcd cpu is defective, here in the philippines we try to re heat the cpu and it works.
Sep 04, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Negatives scan as negatives and not as pictures with the plustek 7300
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
May 30, 2009 | Plustek OpticFilm 7300 Film Scanner
Calapsed picture frame
This can only be a bad soldered on the video module, its better to check for any bad soldered and for any fault on the resistor on the video output module.
Hope this initial info / idea helps.
Please Accept my solution if I solved the issue.
Regards,
micro
Mar 27, 2009 | Televison & Video
Hi guys, Am running Windows XP with SP2 ona Dell Dimension 3 Ghz system. Many of my screen icons will only now display like "tiles" rather than as proper icon. I have a file called icons for all...
you might right click on the desktop, and see what your properties look like..
also, control panel, then display will provide some options, for large and small fonts, right?
check your computers' warranty here 4 FREE
Mar 11, 2008 | Computers & Internet
My scanner doesn't scan negative
" I can only select platen as the sourc. the film setting has vanished" - I had the same problem. Unplugged the USB cable from a shared usb 2.0 hub and plugged into an old USB 1.1 dedicated port and it started working. No ideas why (perhaps in the hub it couldn't detect the scanner model correctly)
Aug 12, 2007 | Canon CanoScan D1250U2F Flatbed Scanner
Open Questions:
How to Remove a Virus from Windows PC or Laptop - DataAlign As the number of cybercrimes and harmful online attacks are increasing these days, it is difficult to keep ourselves safe while surfing the websites of various sites online. If you are looking for a safe online risk reduction scenario, then trust the tech support of TechFree for Toshiba products. Toshiba laptops and other devices get best maintenance and recovery by the services of Toshiba support. Toshiba support provides best risk safety from online threats and also recovery for broken computers and other peripheral devices. Online threats in the form of viruses, Trojans and malwares that are prevalent everywhere pose serious safety threats to the customer's personal information. Various other regular issues like slow computers, snail speed processing, recurrent screen freezing, frequent and without reason computer shutting down and restarting etc. also prove to be a reason of headache for the customers. In case you want all your tech issues to get resolved while you can be busy doing your usual life stuffs then get in touch with the fabulously supporting Toshiba supprot team. You can get the benefit of 24/7 tech support service at your home or office by calling on their toll free helpline number Call Toshiba +1888784-9316 Technicians of Toshiba support got certified for involvement of advanced technology and still making it available for customers at affordable prices. Also, many profitable deals and offers are provided to the customers. Your search for that perfect tech support with features like reliability and consistency is over with Online Toshiba support Email service technique makes delivery of support easier and comfortable for the customer. Also, professional tech services become more trust-worthy with the 30 days money back guarantee it comes with. Toshiba technicians make efforts of delivering the best customer support along with proper knowledge sharing which helps the customers to get proper understanding about all issues and their resolutions. For tech related support contact tech service team of TechFree on their toll free helpline number Toshiba Customer +1888784-9316 anytime. Toshiba support providing professional and certified tech experts will use the most appropriate troubleshooting to resolve tech issues in least turnaround time.
Aug 17, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
