Question about Bugaboo Cameleon Jogger
Brake(?) rubbing on left big wheel when not on level surface or turning
My bugaboo rubs and makes noise on the left tire when I am pushing it leftward or when the pavement is uneven and slopes leftward. HELP!
The same thing happened to mine. I had a good look at what was going on and decided that the length of brake chord is ever so slightly too short. Even with the brake cable adjuster as far "down" as it can go, the chord brings the brake shoe up too close to the wheel making the "raspberry noise" on the left. I got my brand new bugaboo suspiciously cheap and am now wondering whether perhaps it was a factory second because of the short chord.
Anyway, after a bit of tinkering the problem has been almost eradicated, it now only makes the rude noise on the tightest of turns.
1) First, ensure the brake cable adjuster is as far down as possible by rotating it clockwise until you can rotate no further. It can be a bit fiddly so try taking the right big wheel off to get better access to the adjuster.
If the adjuster was not at the bottom before then put the wheel back on and give it another go - it might now work!
2) if not, turn the chassis upside down and identify the thinner cross-bar, just above the "big wheel" axle. You should be able to see 2 screws, one at either end of the bar.
Unscrew the screw at the opposite end of the bar to the brake cable. Now, GENTLY pull the brake at the same end( the green nobbly bit)upwards, towards you whilst re-tightening the screw you've just removed. Only release the little bit of tension on the brakes once the screw is fully tightened.
This step might seem a bit pointless, as it appears that you unscrew a screw, then do it straight back up. Fair point but that tiny bit of flex in the brake/crossbar assembly made all the difference to ours!
I do hope this helps - I really think there is a bit of a design fault here as ideally the adjuster should be set in the middle of the range so that adjustments can be made either side of the neutral. Mine is right on the lower limit and hence has no further room for adjustment. Unless of course it is, as I say, a factory second!! Sorry if I've gone all technical.
Posted on Apr 03, 2008
I have had the same problem on our Bugaboo for some time and decided to have a tinker tonight. What I found was that I had the brake adjusted in too far such that the left sho was rubbing and the brake handle locked at the first click rather than going through to the second lock point.
This resulted in a noisy left wheel and an uneven brake that didn't lock properly.
On my Bugaboo I was able to solve the problem simply by winding out the brake so that there was enough travel in the brake lever to make it to the second locking point.
To do this you need to take some of the spring tension off the brake cable (use your hand on the brake block) and then turn the locking nut anti-clockwise up the thread until the brake lever is able to move far enough to make the second click point .
I hope this helps.
Posted on Jul 04, 2010
Hiya i have the same problem......dont know what to do with it as i bought it second hand...
Posted on Mar 13, 2008
In the right rear I get a rubbing noise when making a left turn or during rapid acceleration.
If the tire started coming apart it could have hit the brake dust cover and bent it.
May 01, 2016 | 2002 Jaguar X-Type
Have rubbing noise when turning to the left on 2007 impala
Rear wheels have the voice of the metal friction surface of brake pads no handle, friction, friction over a period of time or a voice, went to mechanic processing, very simple!auto diagnostic tool.
Apr 12, 2013 | 2007 Chevrolet Impala
My brakes are scrubbing and antilock light comes on, also when ever i back up, my front left wheel makes a very loud noise. kind of like rubbing metal. whats wrong?
the noise is probably the ware sensors on the brake pads making noise the noise lets you know that the brakes are getting thin are are ready to be replaced.if you let this go to long you can damage the brake rotors, make sure you check to make sure the caliper is not sticking on the left side being this side is making more noise ,a stuck caliper can cause premature brake pads ware .
Mar 05, 2011 | 1997 Chevrolet Lumina
I have a 2009 Ford F150 2wd. I added a 2 1/2 leveling kit with 34 in tires and 20 wheels. When I turn it makes a sound like its rubbing. I eventually took it to a brake service center and was told that...
first check its not the tyres rubbing on the mudflaps/wheelarch.or even the inner wing(fender)YOU NEED TO GET SOMEONE TO TURN THE WHEEL HARD OVER WHEN YOUR UNDER THE CAR TO SEE WHATS TOUCHING.......the abs/electronics is just garage ********......
Sep 28, 2010 | 2004 Ford F150
Noise when turning the wheel fully to the left or right.sounds like grinding.
check the inside of the wheel to see if it rubs on tie-rod ends and the tires for wear and tear. also verify what size of tires are recommended, too big the tires will rub on the inside of the fender
Jun 25, 2010 | 2005 Chrysler 300
2004 F150 Fx4, when I turn left makes a rubbing or ruddering sound. Even when im at a full stop and start again it makes the same sound.
Stop with the wheel turned to the left, get out and make sure that there is nothing rubbing. Check to see if the inner wheel well is fastened properly, make sure the brake flex hose is not rubbing on the tire, snow build up?
Jan 12, 2010 | 2004 Ford F150
The front brake on our 2006 Suzuki C50 seems to be rubbing the front tire in one place. It's not enough to slow the tire, but when we put it on jack and turn front wheel, we can hear it rubbing. Is
disc/rotor is warped in one spot, doesn't sound extreme...if it's buggin' you have it turned at a motorcycle shop, otherwise just ride my friend, it's not dangerous....Tim
May 30, 2009 | 2005 Suzuki Boulevard C50
Grinding rubbing noice turning right
If you have stock sized tires on it.. check the brakes.. also look for loose fender skirting near the wheel as a helper turns the wheel maxxed out to the right.. Lemmie know, Thanx
Mar 11, 2009 | 2003 Pontiac Grand Am
Noise coming from front of car
It sounds exactly like a wheel bearing problem.The right side its seems would be the problem. When you turn right it puts more pressure on the bad bearing making it louder. I would suggest replacing both. If on is gone the other one isn't far off. Hope this helps
Mar 05, 2009 | 2008 Hyundai Elantra
1995 chrysler cirrus
jack up the rear wheel and spin the rear wheel to find out what the rub is. look to see if there is any rubbing marks on or in the fender well.( do not have on the emergency brake) Also if the noise could be metalic then it could be the brake drum rubbing on the backing plate.
May 30, 2008 | 1995 Chrysler Cirrus
Bugaboo Cameleon Jogger Logo
1,101 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
