Question about Neff U1421 Double circotherm Electric Oven
Fan The element heats up and becomes red but he fan does not rotate and therefore the heat is not circulated. Some times i works ,other times not. Any ideas?
  • 42 Answers
Mine had this in a Sears Kenmore Elite, the guy changed the fan relay.
Posted on Mar 08, 2008
The fan in main oven only blow out cold air
The fan does not produce hot air. It just circulates it. The thermostat turns on the heating element and the fan moves the hot air around. Unless you have an odd working machine. Baked bread for years an it only moves air for even heat.
Jan 31, 2015 | Ovens
Why does the fan mode on the bottom oven on my zanussi Zou575 not working?
Because in Main Oven Cavity (large) around the convection fan is very powerful ring heating element 2500W (not visible) who works in the Fan mode. Therefore, it is not necessary that all heaters work because it will overheat the oven.
Dado
Aug 25, 2014 | Zanussi Ovens
Just moved, can not get stoves double oven to work light and fan comes on both ovens but no heat
On the main oven, does the circulating fan at the back of the oven start to rotate when you switch it on and does the fan oven neon illuminate as well.
For the top oven, the heating element is not very big so the oven takes a long time to warm up. Does the top oven neon illuminate when you switch this on as well?
Aug 02, 2011 | Stoves 720EF Electric Double Oven
The oven heating element seems to be working but the fan is not working. It appears that the oven is reaching temp very quick and there is a red glow coming from the back of the oven which is where I...
If you can see the element heating up, but the fan is not working, then you need to replace the fan motor assy, if you do not, then the element is in danger of burning out.
Jun 23, 2011 | Ovens
Hello The light, the grill, top cooling fan and main circulation fan all work but the oven doesn't heat up at all. So I assume it's the main element - but isn't there more than one main element...
Yes it does mean that there is a base element, but more likely to be fan element, possibly base element may require replacing as well.
Oct 27, 2010 | Ovens
FAN NOT WORKING,OVEN NOT GETTING HOT ENOUGH
1 How to change a fan oven element and How to change a cooker oven fan Motor
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
1, If the
fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the
element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit i.e. broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven
fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
Mar 04, 2010 | Ovens
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
The fan still circulate on fan bake but no heat
IT SOUNDS LIKE YOUR HEATING ELEMENT HAS BURNT OUT ,FIRST TURN OFF THE POWER THEN LOCATE THE SCREWS HOLDING THE BACK PANEL ON REMOVE ALL THEM AND THE PANEL YOU THEN SHOULD SEE THE ELEMENTS REMOVE THEM BY PULLING OUT THE PULG HOLDING THE ELEMENT IN THEN TAKE IT TO A ELECTRICAL SUPPLY STORE FOR REPLACEMENT REFIT ELEMENT AND YOUR OVEN SHOULD WORK FINE.
Dec 04, 2009 | Baumatic B185 Stainless Steel Electric...
No heat on bottom oven. fan running but not heating up
Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
For all Free appliance repair videos visit our VIDEO TUTORIALS
Jul 19, 2009 | Neff U1421 Double circotherm Electric Oven
Neff U1421 Double circotherm Electric Oven Logo
153 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
