Question about Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD TV WITH DVD&SPEAKERPHONE Television
VE920 on powerup will not detect a cable signal stuck in air mode
When first plugged in according to mannual the unit should go into a 'scan' mode to detect type of signal air or cable. My unit does not seem to do this, seems stuck in air mode. Hence only getting channels 2-13 while plugged into cable. How do I get the unit to auto program and detect a cable signal? Is there some sort of autoprogram button that I can select cable or air??
  • RomAnna Mar 10, 2008
    Thanks, could not get the menu button to work off the remote, but the menu button on the actual unit did get me into some interesting menus.. one of which let me choose 'cable' or 'c'.
    Thanks
    Sergeant:
  • 280 Answers
In your menu from your remote you should be able to find a search mode that you can manually select. at that point you should be able to select source and start a search.
Posted on Mar 10, 2008
How do you clear sc 322 and 302 in ricoh mp 2000?
Charge roller current leak
sc302
A current leak signal for
the charge roller is
detected.
1. Charge roller damaged
2. High voltage supply board
defective
3. Poor connection of the PCU
Laser synchronization error
sc322
The main scan
synchronization detector
board cannot detect the
laser synchronization
signal for more than 5
consecutive 100 ms
intervals.
1. Poor connection between the Laser
unit and the BICU board
2. Damaged cable between BICU
and Laser unit
3. Laser unit out of position
4. Laser unit defective
5. BICU board defective
Apr 24, 2017 | Ricoh Office Equipment & Supplies
LEDTV24FHDF
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
displayed.
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
available.
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
remote.
Apr 08, 2014 | Televison & Video
Computer doesn't recognize garmin
Your computer uses USB Mass Storage Mode to detect your Garmin unit. If your computer does not detect your Garmin unit, you can try these troubleshooting steps:
Unplug the USB cable from the computer.
Turn the unit off and then back on again.
Plug the USB cable into your computer.
The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
If you still experience problems, please contact Product Support.
Garmin car gps
Sep 23, 2012 | Garmin nuvi 1350 Car GPS Receiver
Olevia 232 s12 Accidentally hit factory reset. now no channels in list. how do I get my channels back?
You'll need to reprogram the channels.
Typically this is found under the settings in some sort of auto program section of the menu.
On most newer televisions, the setting is found under a 'Channel' section.
Just select auto program and your source, whether it be an antenna or a cable source.
When the auto program is completed, you'll have your channels back.
Mar 05, 2011 | Olevia Televison & Video
Stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
May 04, 2009 | Sony STR-D1015
No signal
do you have another tv ?? so you can test the cable.
sometimes the cable gets corroted by the distribution box and will obstruct any signal or if you do have signal " on another tv " the cable input on your akai is probably broken, if you have the skills try to open it up as see around the cable input box, most common they get un-solder or loose and won't detect any signal
Jan 08, 2009 | Akai LCT2715 27 in. LCD Television
New dp 19648 sanyo hdtv no signal detected
You gotta have a way to get signal to the tv . If you don't want a outside antenna use rabbit ears .After you hook them up hide them behind the tv then do a channel scan. If you don't pick up all the stations set them on top and scan again or get satillite or cable hd boxes.
Dec 24, 2008 | Sanyo DS27820 27" TV
Audiovox 9'' drop down tv with poor sound
You need to go to cable instead of air and search for channel
Feb 07, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
Bad sound
Being as the set is hooked to a satalight and simply playing what the signal is the problem has to be with the satalight reciever
Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD TV WITH DVD&SPEAKERPHONE Television Logo
88 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
