Question about Quinny Buzz Jogger
How do you close quinny buzz
I CANNOT CLOSE MY QUINNY BUZZ AND I DONT KNOW HOW TO REMOVE CAR SEAT MAX? only got it yesterday lol
  • Anonymous May 22, 2008
    I can't close my quinny buzz - keep pressing both buttons as described but then don't have a free hand to collapse it - which way does it fold?
  • 4 Answers
You need to stand at the front of the pushchair, push in the left grey button and then push the right one down and towards you all at the same time!! whilst doing this push the frame down towards the front wheel! when i first got mine had real problems figuring it out once you do its easy!! remember to hook on the safety catch though cause one touch of the handle and it pops open. i did read that in cold weather it can be a little stiff. not sure on the car seat though as didnt have one! sorry
Posted on May 12, 2008
To close the quinny buzz stroller u must press down the grey button and slide the other grey button at the same time. while holding the grey buttons in the postion u will press down with a little force to bring the stroller flat down. once the stroller is flat down u need to hook the piece on the knob found at the side of the handle bar to keep it closed. if u r not able to fully close the stroller u might not have press down or completely had slid down the button. after a few times of closing the stroller it should go down smoothly. to remove a car seat u must press down on the grey buttons not on the handle thats used to adjust the handle from carrying to sitting position. but the grey buttons on the car seat in front close to the bottom. push down and lift car seat up while buttons are pushed down. this might take practice being that u have to press the buttons down and pull the car seat up but u will find a way either using a few fingers to push the buttons in and the others to grip the handle to pull it up or seaking help. but after a few tries although it sounds complicated u will seek comfort in doing it on ur own and like clock work u would be transfering in and out of the car like the air passing by. goodluck!!
Posted on Dec 13, 2008
I have same problem with my buzz. But the buttom that you push and slide is wobbaly? is this normal?
If not can I get it repaired?
Posted on Jun 25, 2008
Hello I have quinny buzz 3 bundle and want to buy quinny zapp chassis frame. I want to know if I need adaptors for carry cot, car seat and pushcair? thanks
Hi Natalie
Quinny Buzz seat unit is not suitable for use on Quinny Zapp chassis. Quinny carrycot is not suitable for use on Quinny Zapp chassis.
Pop over to our Facebook page with any questions you may have on your Quinny product.
Quinny
Sep 23, 2013 | Baby Gear
Can a Maxi-Cosi Mico infant car seat fit on a Quinny Buzz 2006 frame?
The Mico is a USA model only so we are unable to advise from the UK team whether it is compatible with the older style Quinny Buzz.
We recommend you contact Dorel USA on crelations@djgusa.com
Nov 27, 2011 | Quinny Buzz Baby Gear
I dont know how to attach the second (meant to be bigger) seat to the quinny buzz??
hi
this is the buzz manual you need pages 4 and 5
http://www.quinny.com/media/producthandleidingen/Quinny/manual_buzz3_2010-1.pdf
Oct 21, 2010 | Quinny Buzz Three Wheel Stroller
Trouble opening and collapsing a quinny stroller
The Quinny Buzz can only be folded/unfolded with the seat in the most upright position facing forward. If this is the case and it won't unfold, remove the seat first by pushing down the two grey release buttons either side of the frame. It may be the case that the gas strut (automatic close/opening mechanism) is seized and will need replacing. This can only be done by Dorel UK 01842 763 281 as it is a pressurised unit. Hope this helps
May 28, 2010 | Quinny Buzz Jogger
How do you put the cover on the seat?
If it's the new model then you need to follow this in reverse order for Cleaning the Quinny Buzz seats (comfort cushion and XL seat)
1. Open safety harness
2. Unfasten the shoulder belt snap and hook and remove the belt pad.
3. Loosen all snaps on the bottom of the seat
4. Loosen the Velcro straps on the bottom of the seat. Remove the belt buckle through the opening of the seat
5. Slide the cord of the seats out of the edges of the Quinny Buzz seat. Start with the foot section and work towards the head section
6. Pull the lap belt of the Quinny Buzz seat through the holes of the seats and remove the loops from the shoulder belts from the openings of the seat
May 19, 2010 | Quinny Buzz 3 - Juice Travel System...
Can a buzz seat fit speedi frame
No unfortunately not. The Quinny Dreami carrycot can be fitted as can a maxi cosi car seat using adaptors but not the buzz seat unit.
Mar 06, 2010 | Quinny Buzz Three Wheel Stroller
Can't tell if my Quinny Buzz 3 is suitable for my baby
check out http://www.quinny.com/quinny/default.aspx?language=ch-en
The moulded seat is intended from 6 months. From birth it is recommended with the Maxi-cosi car seat.
Aug 04, 2009 | Quinny BUZZ 3 Capri Stroller
Toddler to big for quinny seat
I had this problem and phoned Dorell to complain. Apparently the new models have a 2nd stage seat that you use from 18 months. I have a 2007 model so I did not get this. Dorell the makers of the Quinny said that the company that I bought my Quinny from can order one from Dorell. So I went into Mothercare. It was a very long drawn out experience but my XL Seat Fabric arrived yesterday after 3 months. Also if you ask Dorell ( you can get the number from the Quinny website- should be a London number) they will send you some strap extenders for free. Hope this helps.
Mar 24, 2009 | Quinny Buzz Jogger
How to change seat covers on a quinny buzz stroller
Try this link
http://www.quinny.com/media/producthandleidingen/Quinny/08.08%20win1299_Buzz4_UK.pdf
The instructions & diagram are in section 6.2 on page 5 of this 7 page pdf document.
Hope it helps!
Nov 26, 2007 | Baby Gear
Quinny Buzz Jogger Logo
383 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
