Apro tv/dvd model al2010 require a sky remote code
SOURCE: Sky remote setup codes
your code is 1239
Posted on Aug 18, 2008
SOURCE: setting up 42lg3000 with sky
i have same tv, this i was i did on mine. on the sky+ remote push tv and then press select + red button at the same time, the red light blinks twice, then push 1174 then power button.
Posted on Jan 07, 2009
SOURCE: Unable to tune my Sky Remote to my tv
panasonic 37in can't pair sky remote with tv
Posted on Feb 16, 2009
rylee_smith
  • 8619 Answers
SOURCE: sky remote control code
Hi!
You can follow the instructions given in the link---
Codes for Sky Digibox
You can also see for reference the instructions manual on the link---
Sky Digibox
You need to just click on the above links and will be able to get the sky remote control code.
Please accept this solution and do rate it as FixYa if found useful.
Thanks
Rylee
Posted on Apr 26, 2009
SOURCE: I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
Posted on Jun 03, 2009
Sky remote code for model UE40J5100AK
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Press "TV" again then enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press TV then the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at:Skyplease remember to use your back button and come back to us.
www.electro-medical.blogspot.com
Samsung brand code 0060
3 digit code for Samsung
065, 584, 037, 245, 476, 398, 516, 292, 318,037
Oct 13, 2015 | Samsung Televison & Video
Code for 37LH3000ZA LG TV
Hello
Get into this link. Enter your TV model number and all details. You can get the code for your Tv frm here.
www.sky.com/.../remote.../operate-tv-with-sky-remo... - United Kingdom
Jan 26, 2012 | LG Televison & Video
Sky remote code for lg 42LD450 42
hi code is 0206 works fine with mine
May 24, 2010 | LG 42LD450 42 in TV
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 4: May 2001 (Sky+ introduced)
Codes are 0065, or 0405,or 0037
Version 6: March 2004
Code are 0065, or 0405, or 0037
Version 8: January 2006 (includes all current Sky+HD remote controls)
Code are 1293, or 1206, or 0206
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
SKY REMOTE CODE REQUIRED
Have since found the answer on the SKY website. Thanks.
May 27, 2009 | Grundig GU26DVD 26 in. LCD TV/DVD Combo
Logik L22LID18 22" hd ready digital lcd tv with ipod dock 7 dvd
Logik TV Sky codes; 1065 0908 1245 0726 0399 0039 0221.
Dec 08, 2008 | Directed 434MHZ Remote Control
Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
May 20, 2008 | Bush WS6671 28" TV
Remote code
You won't be able to use it for your dvd player unfortunately.
The code for sky is 0145.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful.
Gaz
Jan 14, 2008 | Hitachi CLU-4324UG Remote Control
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
