Question about Thermador RDFS30 Dual Fuel (Electric and Gas) Kitchen Range
Clock very dim, oven works but shuts off periodically
I think when this happens, the clock resets as well.
  • 2 more comments
  • petermorrone Mar 08, 2008
    do you have a solution
    do you mean AC power...not that i am aware of.
    The clock is always very dim, on a sunny day, you can hardly read the numbers.
    DOes the display module control the oven?
    Is there a separate power supply or is it built into the display module?
    Have you any experience with this stove?
    Where do you find the part for less than 100 dollars, you dont even know which model it is.
    They seem to go for over 200 dollars. Again, what is your qualification to send me off and spend 200 dollars on a part? Your profile seems to indicate that you are experienced in computer related products, not ovens.
  • 796 Answers
Hello
Posted on Mar 08, 2008
  • 1 more comment
  • isaac johny
    isaac johny Mar 08, 2008
    do you have any power fluctuation??
  • isaac johny
    then replacing the display will be the solution.....
  • isaac johny
    Unfortunately it is not possible to make the display brighter. The only
    solution is to replace the entire clock/timer. The price for the part
    is less then a hundred dollars
Lights showing oven temp are too dim to read -- difficult to set oven temp. model feb756cetf self cleaning wall oven
Good Morning Friend,
I understand the control panel is dim and hard to read, on your Frigidaire oven, model# FEB756CETF. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and set the clock. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire Ovens
Sharp Carousel II (R-9H83) loses clock, digital display dims
I think there are some electrolytic capacitors in the power supply to be replaced.Because there are relatively few, it would be good to change them all for more safety
Jun 02, 2014 | Microwave Ovens
Did I damage electronics after using auto clean feature?
Sounds like there may have been a power failure or problem with the voltage when you were using this or before you did. Try shutting off the breaker for 5 minutes, turn it back on. This will reset the board in the oven. Then see if it works. If it still is defective, the voltage 'surge' may have destroyed the board. You may be able to turn it in to your insurance if that is the case, as from a storm that took out the oven when it hit and the power went out and then came back on. A clue is the keypad lights go dim and brighter then dim again.
Mar 04, 2014 | Whirlpool RBS275PD Electric Single Oven
Jeep liberty clock reset
I think you have a loose cable for the memory
Mar 26, 2013 | 2009 Jeep Liberty
Ge spacemaker microwave jvm1650wh03 randomly shuts off and requires you to reset clock before continuing
The problem is in the keypad control board, this item alone is at least $97.00 for the part and does not include labour.
Jul 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Oct 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Thermador RDFS30 Dual Fuel (Electric and Gas) Kitchen Range Logo
208 people viewed this question
Top Thermador Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
