What type of lanundary detergent to use with my maytag washer.
  • 49 Answers
Is it a top loader or front loader
Posted on Mar 08, 2008
Maytag front washer displays code: SUD5. What does that mean and what should be done.
Too many suds. Either too much or wrong type detergent is being used. Run a load without soap to clear it.
Nov 07, 2017 | Maytag Washing Machines
How do you clean a Maytag Neptune top loading washer
Tip: Prevent a Smelly Washer With Powdered Dishwasher Detergent
I have a great tip for making a smelly clothes washer smell fresh and clean, given to me by a Maytag repairman. Simply run dishwasher detergent powder, not liquid, through your machine with no clothing in it, about once or twice a month.
It works and it is cheaper than the specialized products that do the same thing. Use the same amount you would use of laundry detergent for your particular machine.
Aug 16, 2015 | Maytag Neptune Washing Machines
Where do i put liquid detergent in top stacking may tag older model
Just pour the liquid/powder into the wash tub prior to loading clothes... this machine does not have a detergent dispenser...
Jul 06, 2014 | Maytag Neptune MAH5500B Front Load Washer
Maytag neotune error sud5
Too much soap or wrong kind of detergent if HE washer. Run the washer empty with 2 tsp of cooking oil. The soap will attatch itself to the oil and remove the excess detergent residue.
Jun 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
A white stain or powdery residue remains after washing dark colors
This often occurs as a result of overloading the washer. If a washer is overloaded the water cant get in between all of the clothes to thoroughly rinse them out. That will cause streaks of white (which is most likely the unrinsed detergent).
Also, make sure you are using the correct water level setting for the load size.
If a washer is overloaded continuously it will cause premature parts failure.
Other cuases can be related to water hardness and the type of detergent you are using.
Try using a detergent with smaller granules or even a liquid detergent.
Make sure you are not using to much detergent for the load.
One other thing, turn the water off to the washer, remove the hoses from the back of the washer and check the screens that they are not corroded, if they are replace them. You can get these at Ace hardware, lowes and maybe even wal-mart. Corroded screen will impede water flow hense not allowing a good water flow during rinse cycle.
Mar 13, 2011 | Maytag Washing Machines
After a wash, my Quiet Series 100 Maytag washer has fine grit all over the inside of dishes. Is there a filter somewhere I should be cleaning?
Try changing the brand and type of detergent that you are using. Some seem to work better under hard water conditions. Hope this helps.
May 07, 2010 | Maytag 24 in. MDBH950AW Built-in...
Can you use regulure detergent instead of the HD kind? The type of maytags I purchased are MEDE500VW and MHWE450WW washer
High Efficiency detergent is strongly recommended for front-load washers. This detergent is a "low sudsing" detergent as opposed to the regular detergent. If you use regular detergent is a front-load unit, you may have issues down the road!
Apr 13, 2010 | Maytag MEDE500W Dryer
Washer flashing 02 F. Maytag epic washer won't spin -flashing 02 F about 15 minutes into the cycle. We just had new electrical components put into it.
You need to use the HE detergent. I believe that is a drain problem. By using the regular detergent that causes more suds and in turn clogs your drain
Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Detergent goes where?
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 9 years for me.
Jun 28, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
