After gioing into control panel, display, settings, advanced, adapter, properties and selecting do not use on the device usage, because I was having problems with my hardware acceleration. I now cannot see anything on my moniter so in hindsight I have done something silly but I was hoping that my windows would reset the drivers in the hardware setup after restarting the computer. Now I cannot do anything because on windows start up my moniter is blank. I have tried entering in safe mode but my computer freezes everytime i try. Is there anything else i can do to rectify this problem in the initial setup after hitting the delete button?
    Genius:
  • 1,601 Answers
NKing879:
Try hitting the F8 key when you start your computer. It will take you to a menu screen. try choosing LAST KNOWN GOOD
Posted on Mar 08, 2008
How do I get rid of a flashing message "Display Mode out of range"
Here is an article from Microsoft on this problem. Good Luck !
20x20_grey_minus.pngCause This behavior can occur if the signal from the video adapter exceeds the scan range of the new monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor. uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.pngResolution To resolve this behavior, either change the refresh rate, or change the video adapter settings.
To change the refresh rate:
  1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
  2. Right-click the desktop, click Properties, and then click Settings.
  3. Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
  4. Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties.
To change the video adapter settings:
  3. Click Advanced, click Adapter, and then click Change.
  4. Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
  5. Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
  6. Click Standard Display Adapter (VGA), and then click Next.
  7. Click Yes, click Next, click Finish, and then click Yes to restart the computer.
  8. After the computer starts, right-click the desktop, click Properties, and then click Settings.
  9. Click 256 colors, click Apply, and then restart the computer.
  10. After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
  11. Click Device Manager, click View devices by type, and then click Display adapters.
  12. Click Standard Display Adapter (VGA), click Remove, and then click OK.
  13. Install all updated monitor drivers.
Jan 24, 2015 | Computers & Internet
Solution for aspire 4745g when installing for ati driver it turn black?
An ATI adapter is a type of video adapter that is designed to be used on computers running Windows. If the adapter is disabled, you will not be able to connect any external monitors, video projectors or other similar devices to it, as your operating system won't be able to recognize it. Of the different ways you can enable this type of display adapter, one is through the "Display" manager in the Control Panel.
Click "Start." Click "Control Panel." Click "Display." Click "Change Display Settings." Click "Advanced Settings." Click the "Adapter" tab. Select the ATI adapter from the list on screen. Click "Properties." Click the "Driver" tab. Click "Enable" to enable the ATI adapter through the "Display" manager.
Or the driver you are installing is not compatible with your operating system or your computers hardware
Hope it helps
Jan 23, 2013 | Acer Aspire 5602WLMI Notebook
How do you disable the on board videocard on a hp p6130f?
Turn on the computer. Press the left "Ctrl" key. When the start-up menu appears, select "Safe Mode" and press "Enter." Once the computer enters safe mode, click the Windows "Start" button. Go to "Settings" and open "Control Panel."
Double-click the "System" icon. Choose the "Device Manager" tab. Press the "+" next to "Display Adapters" to view installed display adapters. Highlight the adapter listed and click "Remove" then "OK." Close all open windows and restart the computer.
Press the "F1" key at the blue HP screen. Enter set-up and press "F5" and "Enter" to reset all data. Press "F10" to save and exit.
Right-click the "My Computer" icon on the desktop. Select "Properties" from the menu. Click the "Hardware" tab, then the "Device Manager" button. Expand "Display Adapters" and right-click the graphics card. Select "Update Driver" from the menu.
Choose "No," and hit "Next," then select "Install From a List." Select the option to show all hardware. Choose "Standard Display Types." Select "Standard Display Adapter (VGA)" and hit "Next." Don't restart the computer.
Click the Windows "Start" button. Go to "Settings" and open "Control Panel." Click "Add/Remove Programs." Remove any i810 and i815 chipset programs. Restart the computer. After it starts up, go into the "Display Adapters" section in "Device Manager."
Open the "Standard Display Adapter (VGA)." In the properties window, un-check the box "Exists in All Hardware Profiles." Click "OK" and shut down the computer. Open the computer case. Install the new video card according to the manufacturer's directions
hope this helps
Aug 26, 2012 | HP Computers & Internet
T43 Screen portrait
Click Start/Control Panel/Display/Settings/Advanced and look for the Rotation Tab. Your screen has been rotated and it is controlled by the video card adapter.
You can also get there by Right Clicking on an open area of your desktop and select Properties and the display will open. Then select Settings/Advanced and look for the Rotation Tab.
Jun 08, 2012 | IBM ThinkPad T40 2373 Notebook
My aspire screen is upside down and the picutures are also upside down. How can I fix it?
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Apr 02, 2011 | Computers & Internet
Have a power but no display even the video card is good
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also
If your computer came with a motherboard disc the drivers could be on it
also
hope this helps
don
Feb 14, 2011 | Computers & Internet
My toshiba microphone is not working
These are steps to ‘setup’ and ‘restore the "Audio Drivers.” Part (1) Go to the Control Panel, select "Hardware and Sound." In the next window, click on the "Sound" category; next select, "Manage audio devices... "Once the window open, select "Recording," click on the "active "Microphone," click on the "Configure button" make all necessary changes. Part (2) Click on the "Start" button, go to, and click in the (right, pane), the Control Panel. “Scroll to find, "Ease of Access (or) Speech Recognition Options.” Next, select Replace sound with visual cues." In the See also: (Category), click, on “Audio Devices click on the, 'Playback' button, select the 'Active' Speakers. Select, Configure to: "Audio channels" The (Speaker Setup) "wizard,” appear! Select (Test) click, the “Next” button. Follow the instructions. Part (3) Click 'Properties' change the "sound"(Level). Select 'Enhancements', "Apply" changes. “The (Advanced), “not recommended!” In, the (“Controller Information”) block, click on the, Properties to "update" Drivers. “Check to see if, Device usage: (enable) if not? “ Change it. Part (4) Next, go to the Properties to view: Device Usage: ("enable), "Update Driver." Note: Select buttons "OK" to all changes “Save and Apply!” Restart the computer "Did this solution help?” If so, "Helpful Rating Feedback," appreciated, thanks paul7of9"
Feb 25, 2010 | Toshiba Satellite L305-S5921 Notebook
Attention out of range is displayed on ibm 2 74 monitor
Apr 13, 2009 | IBM E74 17" CRT Monitor
Out of Range message displays when PC boots
The settings that you have for you tower needs to be changed if you have a old monitor connect that to the tower then right click on your screen go to settings and set it real low once this is done connect the new monitor up and set where you would like it,
The out of range is just letting you know that the settings thats set the monitor can see
Mar 12, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
I changed Desktop resolution setting to higher, Monitor went black with "Out of Range" message
please try this:
hope it helps!
Nov 02, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Computers & Internet Logo
41 people viewed this question
Alun Cox
David Payne
David Payne
