Wharfdale dvdr24hd160f I have put a data disc in my Dvd recorder by accident and now I cant eject it or do anything with it. It just stays on the dvd welcome screen it was working perfectly well before this how can i take out the disc without taking the machine apart?
I had the same problem where the screen keep saying "preparing". I had tried to switch it on and off, but it didn't work. As there is not a small hole for manually ejecting the disc, I just kept pressing the eject button repeatedly (about 25 times) and the drawer opened. Grab the disc as soon as it opens, as the drawer will immediately try to shut itself again. If this does not work, then trying repeatedly pressing the power button to try to get it to reset. Then repeatedly try the eject button again.This sounds mad, but it worked for me.
Posted on Feb 13, 2009
  • 655 Answers
Ok
Look at the door of your DVD shutter. There might be very small hole. This is an emergency Shutter open point. Make off your player, insert a long pin inside the hole, press it gently, you will notice that the shutter is openning, pull it out side, and take off your data DVD from the tray.
Thanks
Iqbal
Posted on Mar 08, 2008
I have one bundle of Verbatim blank DVD's with printable surface. When I tried to recode it says " insert blank DVD " or it is ejecting automatically. I tried in different writers with new blank disc ,...
this may sound strange but what is the rom's you are trying to use them on as some rom's will not take 8x recording or R - or + and it will say there is no disk and ejecting the disc. and dvd disc only work with dvd drives designed for instant record. most models take data/dvd disc as it can be formated in both formats to record but dvd is just one setting that most dont have.
Oct 18, 2013 | Verbatim 94889 - Datalifeplus 8XdvdR Media...
What type of disc do you need to record, I bought DVD+RDL but it keeps ejecting
What are you trying to record on.First you need a recorder.You cannot just put a cd or dvd in a player to record.They are play back only.Now what media are you putting in your recorder.If it is a cdr it will not record on dvd.What you said is you are using a dvd+rdl which is a dvd+ media with double layer (meaning 9.4 gig instead of 4.7 data).Any dvd recorder can handle the dl media.Look on the facinfg of the carriage and it will tell tell you the media intened to be used. cdr/cdrw or dvd/dvd-dl.Hope this helps
Apr 29, 2011 | Televison & Video
Quite simple, I have an LG video recorder, and a Wharfdale dvdr24hd160f, both in line to my TV. Is there any way I can record old family video tapes to DVD, without interfering with my current wiring...
Hi, You should be able to depending on how your DVD is connected up. If it is hooked up using a yellow, red, and white lead (RCA. Common lead with a pin in centre of plug) there it should be no problem. On your TV there should be a set of sockets of the same colour. These should say monitor out, our output. Basically this set of plugs will send the picture and sound of whatever you are watching on the TV. If you connect from your monitor output sockets on your TV, to the input on your DVD recorder (will likely say AV1, or input on your DVD recorder) then it should record your video. You just have to make sure that the picture on your TV is the video you are playing, and the channel that is set to record on your DVD recorder is AV1. (You may also have an input at the front of your DVD recorder that says AV2 or input 2.) As long as you set your DVD to record the input set of sockets you plugged your cable into it should work. This set up will not alter the operation of your DVD or TV.
Oct 26, 2009 | Televison & Video
When I put a blank dvd+rw or dvd+r in it asks me to format,I say ok and then it asks the same question again,if I say no it ejects the disc.Hence i cant record anything.
It sounds like the discs are not compatible with your dvd recorder...if they're 16x, then try 8x and see if that helps. Also see if you can find a list of compatible discs in the manual or online. I hope this helps.
Oct 06, 2009 | Cyberhome CH-DVR1530 DVD Recorder
DVD will not finalize or play after recording
Try using it on a PC/Mac DVD drive, they can usually read open session discs and if so you can save the data and re-burn it to a fresh disc.
Jul 03, 2009 | Sanyo Televison & Video
Dvd will not eject
This used to happen periodically with my unit. I would just unplug it and then whatever was stuck would pop out.
Jul 21, 2008 | JVC DR-MV1S DVD Recorder/VCR
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
Goodmans home dvd recorder
Make sure the DVD has been finalised. When you finalise a DVD the recorder puts all the disc content information at the start of the disc so that any device you put it into can find out what is on the disc without scanning through 4.7 Gigs of data, (which would take so long it would drive people mad everytime they put a disc into anything). Because the table has not been written the PC cannot see what is on the Disc.
Another possible answer: some makes, Orion for one have a Virtual Record mode that it was not possible to play in any other device.
And Orion do make products for Goodmans.
Most likely the first answer though.
Feb 17, 2008 | Sony DVP-NS530 DVD Player
Wharfdale DVDR24HD160F
Hi Barb22,
Sounds faulty to me, I'd take it back to the store and get a replacement. However, I guess you want that DVD out first? I'm not sure this will work because the units logic board is mostly likely faulty and will prevent the DVD transport from opening. Unplug the unit and press the eject button, keeping it pressed plug the unit back in. If the unit does not come on then press the power button too. If the unit starts to open release the button immediately. It's unlikely to eject, but you might get lucky.
Sorry I can't be of much further help.
Regards,
Spare head 2
Please don't forget to rate this response.
Jan 13, 2008 | Wharfedale DVD-M3 DVD Player
Repairing disc message won't go & DVD disc won't eject
By pressing the Power button for >10 seconds you can force the unit to turn off. Immediately as the unit does, press the disk eject button and the defective DVD can be removed. Don't put it back in, or the problem may repeat!
Nov 17, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Televison & Video Logo
233 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
