Question about Harman Kardon AVR 135 Receiver
110 Volts plugged in 220
Something got off inthe AVR because of wrong power input
what all could have got burnt because of this
what do u suggest
can i get it repaired or should i go for a new one since waranty is over ?
Ram
As suggested above the Power Transformer inside it got fused and some ic's near the output section got blown.
got the transformer rewinded and replaced the fuses.
Now my system is ROCKING
Thanks for the suggestion
Ramudu
Posted on Mar 30, 2008
  • 807 Answers
More than likely just the power supply would be damaged, it should blow before the rest of the unit gets damaged. Maybe even just the fuse inside where the power lead connects is blown.
Posted on Mar 08, 2008
I plugged my max 110 V Oliso iron into our house's only 220 V outlet. Smoke is being emitted and it is unusable (The iron, not iron). Can someone please tell me how to fix it?
are you saying that the iron works with 110 volts and you plugged it in a 220 volts outlet??? if so then the voltage is to high for the iron (luckily it didn't get burnt) but all you need to do is plug it into a 110 volt outlet
Jun 23, 2015 | Oliso TG-1000 Iron
110 volts, rated TV was plugged into 220 volts power supply. Now when it was plugged into an 110 volts supply its not getting on? What could be the causes? and please suggest solutions.
It probably fried the power supply in the TV unfortunately. If the electrical surge stopped there then it should just be a matter of swapping out the power supply. Provide a make and model of television and I will see if I can help find one with instructions on how to change it.
Nov 24, 2012 | Office Equipment & Supplies
I accidentally plugged computer avr 220v to 110 could it affect my power supply
If the computer power supply is a 240 volt unit and you plugged into 110 volt mains the the computer should be OK.
Some power supplies have a voltage selection switch on the back of the power supply switch to 110 volts and it should work.
If the power supply is 110 volts and you plug it into a 240 volts mains then you will damage the power supply and possibly the computer as well.
Mar 14, 2012 | HP Pavilion a465w-b PC Desktop
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
Plugged a 110 volt kenwood receiver accidentally to 220 volts
Considering 220 and 110 systems have different receptacles, you worked at doing this.
Since it is already inoperable, you may as well remove the housing and inspect the guts. If you see burned traces or boards, don't bother to have it repaired.
If you see a fuse in a clip, you might replace it once, two would be the waste of the second fuse.
Aug 23, 2009 | Harman Kardon AVR 135 Receiver
Accindentally pluged it to 220 volts instead of 110 volts
hello , i suggets you replace the power supply with a 110 v input boerd .
or do this if the damage is big replace the all sytem with a new one then get a voltage step down ie 220 to 110.
thank you
May 06, 2009 | Yamaha DVR-S120 DVD Player
Neptune dryer
there is no transformer in the dryer, i am guessing you have a 110 v motor and when you hooked the plug wrong, you could have supplied the motor with 220 v that's why you can smell something burnt.
the heater is 220 volts. regular dryer has dual voltage supply. 110 v and 220 volts.
tnx 4 using fixya,
drcool
Sep 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
No power no sound
oh noh!!! I suggest you should an AVR (automatic voltage regulator), these will help to control the flactuations of power. try also check the power supply (its either 110 or 220 volts), just make sure it is compatible to your default power supply.
Feb 05, 2008 | RCA HD52W58 52" TV
To Arpi > PS2 U.S.A. version (110 volts) SCPH-39001 charged to 220 volts - is it burnt already?
This would have damaged the power supply, most likely not harming any other parts. Fuses do not smell when they blow so something else was damaged. I would suggest looking for a similar revision that has a blown laser or other trouble and use the power supply from that.
Jun 02, 2007 | Sony PlayStation 2 (PS2) Console
Harman Kardon AVR 135 Receiver Logo
200 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
