Pioneer VSX D814 will not power up - Audio Players & Recorders
  • 7 more comments
  • Mike Vigil Mar 08, 2008
    Got this from a friend... dead as a door knob, he doesn't remember wha thappened.. just one day it didn't work.. I've been inside the unit.. no obvious suspects..No bad smells.
    Main fuse is OK and correct rating.
    I have found no other VISIBLE fuses ( glass style ) but there are surface mounts on a PCB for the power transformer, on the secondary side for the amp AC rails.. those are fine as well.
    yes I have tried unplugging & repowering a few times.
    The standby powers system works & there is 5V to the on / off sw.
    if you press the button nothing happens.. nor tries to.nothing is displayed.No error codes.
    The outputs are Sanyo large scale monoblock chips ( 2 of them )
    thought's?
    Thanks
    Mike
    And no blown caps ( at least not venting or party popped )
    And SORRY VSX-517 not 817 ( I was ordering a part for my 817 when I posted this )
  • Mike Vigil Mar 18, 2008
    Actually nothing.. reciever is still dead as a door knob.. sitting on my project bench.. waiting for guidance... I did however stumble across the following.. in the bigger units there is a pad for an LED behind the power switch.. which in this case, on this model is not stuffed.. I get a 1 second 5 volt pulse...
    I assume this would be a blinking LED..
    I would further assume RED..
    the front display does nothing.. no error codes.
    HELP!
    Thanks
    Mike
  • Mike Vigil Mar 20, 2008
    Just putting out there again for more input
    Replaced the glass fuse.. no change
    Voltage on both sides of fuse.... since the +5 supply is alive...
    I'll look into getting a factory service manual
    and see about this reset.....
    Mike
    Pioneer VSX-517
    Putting the this ball in the air again
  • Mike Vigil Mar 21, 2008
    OK guys here's the REAL DEAL...
    The 517 will NOT power up nor show any display IF it has detected an amp error in it's past... it will just do a DUH! Like I was having. You can force the unit to power up by pressing the direct button & enter for 2 seconds.. it will cycle through a start up then trip a general error code.. in my case AMP ERROR...the unit will keep alive for about 2-3 seconds.. then full shutdown..There are 5 wires from the output chips to the relay section of the board ( white, red, brown, blue, yellow ) these correspond to the output devices.. in my case 1/2 of the STK412-530 ( brown ) right surr was playing grab the rail and putting out 63 volts! WOO HOO... on that 1/2 of the device the output was on pin 11 which I cut
    so no output would get to the board, nor the fancy pants error detection circuts.. and BINGO I'm running on 4 of 5.1 channels.
    The unit powers up & down properly and all the displays & buttons function normally.
    I'll now find a source for the monoblock amp's and I'm done.
    Hope this helps someone else in the not to distant future.
    Thanks for the assist's
    Mike
  • Mike Vigil Mar 22, 2008
    Jamie..
    I figgured it out read my last post
    Master:
  • 377 Answers
  • 2,336 Answers
Have you connected this device with the speakers and try to get some sound out of it?
The reason I ask is because in many cases the voltage that powers up the front display is missing but everything else works, I have fixed quite a few receivers with that same failure but not this model in particular. If you have the schematic diagram, check for 32 volts DC that powers up the front display.
I would suggest to check the AC voltage that comes out of the big transformer, if the AC is there; check for DC around the biggest capacitors.
Let me know if you require further assistance.
Posted on Mar 20, 2008
  • Jaime Hernandez Mar 25, 2008
    Thank you for the great feedback vigvette.
  • 4,234 Answers
I think that the microprocessor is probably smoked. Look for the main power relay. It will be on the same board as the standby transformer. There should be a small TO-92 style transistor very close by. Short the pins (center and one leg) and you should here the relay click on. If the unit powers up OK, then the problem is most likely the micro.
Dan
  • ABRsvcs Mar 20, 2008
    A factory "reset" won't fix this. Try turning on the unit by shorting the legs of the relay driver like I suggested. With the unit being off as long as you have described, the "reset" should have already occurred. I'll look up the micro part number tonight.
    Dan
  • ABRsvcs Mar 22, 2008
    You can search the web for the STK or you can get this directly from Pioneer. If you can get to a Pioneer distributor, the part will be less that from Pioneer directly.
    Dan
    Genius:
  • 3,422 Answers
Your receiver has internal overload protection systems to prevent permanent damage. On SOME Pioneer models, these can be "reset" but you can't do it yourself. Your dealer or authorized service center must do so.
Goodluck..
  • Priya darshan Mar 20, 2008
    I also suggest you to try replacing the glass fuse once before taking it to the service center.
    Guru:
  • 1,894 Answers
Problem is at what level.
how much have you got solved?
Posted on Mar 16, 2008
  • 796 Answers
Hello
Posted on Mar 08, 2008
  • isaac johny
    isaac johny Mar 08, 2008
    did you try removing the input power cord and again replacing it again....
    did you view any error code before???
  • isaac johny
    check to see if you put the correct fuse in the receiver, and if it is
    the correct one, you will need to check the protection circuit because
    with it being turned up so loud the amp was probably damaged. in most
    cases with protection circuits you will probably find your problem with
    an output transister. than check for blown caps.
How to repair pioneer vex-D814 which has no power?
Bringing it to the repair shop may be a better idea if you don't know where are fuses and power card.
Jan 22, 2018 | Pioneer Audio Players & Recorders
I have the pioneer vsx-d814 with the xxd3069 remote but the remote wont work anything and it has power.Need help
Hello
Get into this link and see the faults that can occur with a remote control. Just check all that suggested. Even after all che checks are found OK ,and your device does not repeond to the remote control, the remote sensor inside the unit must be checked.
http://www.fixya.com/support/r8733688-common_faults_in_infrared_type_remote
Dec 15, 2011 | Pioneer XXD3033 Remote Control
I have a pioneer vsx3700s receiver,can you tell me where i can find a schematic or repair manual for it?
www.stereomanuals.com
G12 price code = $21.00 + $2.00 shipping
Pioneer VSX-3700S AV Receiver Service Manual = G12
COMMENT: (1990) Also VSX-3600, VSX-3900S, VSX-3800, VSX-411S, VSX-401. (IMPORTANT NOTE) Circuit Diagrams and PCB Pattern Layouts (and Exploded View, Parts List) only, balance (if any) of manual on (1) (not included) microfiche card. There are some separate manuals which are almost entirely for the Remote Controls: for VSX-411S and VSX-401, see VSX-411S. for VSX-3900S and VSX-3800, see VSX-3900S.
STOCK# = PIOVSX3700S-SM
DESCRIPTION: 56 total pages (18 intentionally blank), constructed as the original including (almost entirely) 11in x 17in folded /trimmed pullout pages, card stock covers, neatly assembled with 5 staples and fiber reinforced taped spine. Models covered: VSX-3700S, VSX-3600, VSX-3900S, VSX-3800, VSX-411S, VSX-401. Overall quality is Very Good.
Feb 24, 2009 | Pioneer Audio Players & Recorders
Pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Dec 18, 2008 | Pioneer VSX-D510 Receiver
Pioneer vsx-d814 will not power on after power surge
I pressed the front Enter and Advanced Surround for 2 seconds on my VSX-D814 and that worked. Thanks.
Mar 21, 2008 | Audio Players & Recorders
Center channel
Just to rule out the easy solutions, have you made sure no settings changed? Make sure that you didn't accidentally turn off any surround sound settings or turn off the center channel in the MCACC setup or the like (I have the VSX-D814, so your receiver should have MCACC as well). If you're sure no settings changed and the center channel should be working according to the receiver, then it would appear that the center channel amp went out in the receiver. You can either get a Pioneer service center to take a look at it, or if you're comfortable with electronics, I believe you can get the parts straight from Pioneer.
Dec 10, 2007 | Pioneer VSX-816-K/S Receiver
4,256 people viewed this question
 Grubhead
Grubhead
