Question about Uniden Cordless Phone
GE cordless 900 mHz
I purchased a new phone and don't have a manual. I have charged the phone for 24 hours. The base unit will dial, but when I try to use the cordless phone there is no dial tone and it states "No link to base". Does this mean the battery may be dead?
Thanks
  • 3 more comments
  • Hannah213 Mar 08, 2008
    Thanks for your help
    26936GE1-C model no.
  • Hannah213 Mar 12, 2008
    Thanks so much for the manual. It did help me with the phone options, but unfortunately, it did not explain my problem.
  • MrMidas Mar 19, 2008
    I ought the phone second hand (I wondr if its the same one she had) after searching the user guide I toi found no mention of how to resoolve this problem.
  • MrMidas May 11, 2010
    i checked the hanset and base numbers to make sure they matched. they dont appear to have been switched. I get a dial toneon the base and the speaker phone works. When i press the pager on the hanset it will beep the base but then the no link to base error comes up. when i initiate the page from the base only the base beeps.
  • 405 Answers
Wow, This took quite some digging around to find, but here it is all 104 pages of the manual.
Follow this link:
http://157.254.235.130/public/15721090_R2.pdf
Hope this helps
Posted on Mar 12, 2008
I cannot receive my messages...help please
Posted on Mar 09, 2008
Where do i find a manual for a ge cordless 900 Mhz model #26930ge2 Phone It is set in French.How do i change the language to English. Thanks
http://www.epartner.atlinks.com/Thomson_asia/GE/file.aspx?filename=GE/product_docs/26930-UserGuide.pdf
Aug 25, 2011 | Uniden Cordless Phone
GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
May 21, 2008 | Uniden Cordless Phone
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
How do I upload a Product Manual?
I don't know, but i need this manual
May 16, 2008 | GE Cordless Phone 900 MHz
Unable to dial out
This is wild, tomorrow's post today. Check the phone to see if it is in pluse or tone. Try changing that. Is this a cordless phone or a cell phone? If you changed a cordless phone batterie chech to make sure the new batterie plug is the same color as the old one. Some are black and some are white and the polarity is opposite.
Feb 13, 2008 | GE Cordless Phone 900 MHz
Please register
I charged my three brand new GE model 25922 for 24 hours, placed each handset in the main base to satisfy the "PLEASE REGISTER" message and the message remains. The only instruction in the manual as well as on the 800 448-0329 # is to place each handset in the base unit for 20 seconds.
Dec 03, 2007 | Uniden Cordless Phone
2003 Phone- no dial tone GE CORDLESS 900MHz
I am having the same problem with general electric model 27939ge3-a . I am very displeased with the GE website(s) as it is difficult to manuveur around to find any user manuals.
Next time I purchase a phone, I will check the manufacturer's help support first.
As to a solution. I may try purchasing a new battery. Perhaps it is a power issue
Oct 30, 2007 | Uniden Cordless Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Uniden Cordless Phone Logo
251 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
