Question about Cell Phones
How can i hook my bluetooth up to my verizon phone? i have the vx 9400 and my bluetooth is the older model of the bt350
    Problem Solver:
  • 13 Answers
if you are using windows xp, and your computer has a bluetooth chip, its quit simple.
first enable the bluetooth in your computer, then activate the bluetooth in your phone and make sure the phone is in "visible" mode. Otherwise the computer will not be able to find it.
go to the control panel of windows, open the "bluetooth devices", and click the "Add " button. it will scan for new devices. when it finds your phone, double click on íts icon. you will at this point be asked for a "pass key" just enter "1234" - do the same thing on the phone.
at this point you have paired the phone with the computer and can not send files back and fourth between the devices.
Posted on Mar 08, 2008
Get jabra in discoverable mode
ok i finally found out.. Turn on the jabra unit once on hold the answer button AND the volume up button at same time till u get solid blue light... It will flash like 8 times then go solid... At that point it can b found by all ur devices... the passcode is 0000... Enjoy
Apr 14, 2009 | Jabra BT350 Bluetooth Headset Headset
I dont know how to pair my jabra bt350 with my lg dare from verizon
hello mom. try putting your phone into activate new device and than your tooth into discover mode, than your phone will ask you for password key and put in 0000 and press the o.k. button and pair it. it works most of the time. good luck.
Jan 24, 2009 | Jabra BT350 Bluetooth Headset Headset
LG VX-9700 and bluetooth headset cuts out and choppy
Solution is questionable. Talked to Verizon Tech (Good support) and shortly to Plantronics. Both claimed to know nothing of a problem with the LG Dare and Bluetooth. Went back to the Verizon shop in the Mall to get it checked. We duplicated the problem on both phones and also used their phones (not the VX-9700). So, they are sending two new LGs to us via FedEx. When we came back to pick up the phones, the Tech did some research and did find info (Verizon) and Bluetooth. He did not elaborate.
Also there IS a Firmware Update for the VX-9700 and you must take it in to a Verizon that has a flash machine to upgrade the probably 03 to the latest, 05.
Thanks Also, hope this helps someone else experiencing Bluetooth problems.
Lou
Oct 03, 2008 | Cell Phones
How to hook up a Jabra BT350 bluetooth
Make sure your cell phone's bluetooth is activated. Once you do that, you should be able to hold down the main button on the Jabra and once it turns on, it will connect with your phone.
Also, go to this site for Jabra. It links directly to the manual.
Jun 22, 2008 | Jabra BT350 Bluetooth Headset Headset
Pairing
I'm having the same problem with my verizon vx8600 phone. Only with a jabra bt350 (listed as compatible). It actually doesn't find anything at all, no phones, no headsets, no bluetooth enabled PC's. Not really sure what to do since I've discovered handsfree talking, I never want to go back
Jun 08, 2008 | LG Chocolate Clamshell VX8600 Cellular...
Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Nov 30, 2007 | Jabra BT350 Bluetooth Headset Headset
Cell Phones Logo
42 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
