Question about Philips 60PP9352 60" Rear Projection Television
PHILIPS TV MODEL # 60PP9100D/37
TV HAVE NICE PICTURE BUT NO AUDIO, I CHECK THE AUDIO CIRCUIT AND FIND NO PROBLEM.
THANKS
  • 99 Answers
Check your speakers, your cables going to speakers and try to use a headset, if you hear sounds in your headset the problem is your speaker .
Posted on Mar 10, 2008
I have Philips Flat Tv model # 42pf7320a/37 ..I have a clear picture but no audio, just white noise and static.
Clear picture but white noise and static?!!!!!. What do you say?. Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jul 23, 2015 | Philips 42PF9630A 42 in. Plasma Television
The color is off there is too much red in my 60pp9100d/37
Philips TV's have a reputation of bad coolant fluid. This fluid is found between the picture tube face and the projection lens. The coolant starts turning a milky brown color and causes the picture coming through it to be degraded. This envolves removing the picture tubes and changing the fluid. This is a very complicated repair because it envolves convergence adjustment after it is reassembled. Most shops charge about $300-$400 bucks to do this. Have a shop check it out for you and make sure that is what the problem is. Thanks for using fixya. I hope this gets you on the right track.
Nov 04, 2009 | Philips Televison & Video
Good picture, no sound
Hi, sounds like a Philips flat panel could not find a manual for this model, if you have tried both DVD and cable box and both produce no audio. & check the speaker is turned on in the menu of the TV. then you have a problem in the audio amp circuit of the TV, Philips had a problem with some back in 2003 and it was the SSB board that needed repair or replacement. It may be cheaper to just buy a stereo surround system and run both cable box and DVD straight to the surround system.
sorry could not be of more help.
gd lk
Eric
Aug 13, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philips 60pp9100d/37 - remote sensor
Yes it probley got pulled out and since
its a stragler wire ,it would be easy to miss
little trick I use is never dust or vacume
till your done , that way you can see where
somthing was or was not pluged in at that
location
darn gota take it apart again , I know the feeling.
Jun 30, 2009 | Televison & Video
Philips 60pp9100d/37 convergence issues
Did you replace the 6.8 ohm 1watt resistors? As that model will usually blow a couple when the ICs fail.
Apr 21, 2009 | Televison & Video
Phillips Model 60PP9100D/37
Its a common problem on this model. Most likely the HVG. Goto www.TvRepairKits.com for a kit with instructions.
Apr 19, 2009 | Philips 60PP9200D Television
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Mar 10, 2008 | Philips 60PP9352 60" Rear Projection...
Philips 27p6441/37 has a foldover
Bad capacitor / IC in vertical circuit...usually a shop repair...
If not corrected,could get worse in short period of time,.....T.
This model also requires an upgrade kit for future reliability...
Philips part number 483531057673 senior tech only.......
Jan 21, 2008 | Philips 20PT6441 20" TV
NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
check the wires inside at the left lower region as you are looking at the rear. There are several circuit boards there that tend to loosen when moved. The cables are really ribbons like those used in computers.  I'd lioke to be more specific however I'm not entirely familiar with this model, just rear projection tvs in general.
Sep 05, 2007 | Philips 60PP9200D Television
Philips 60PP9352 60" Rear Projection Television Logo
143 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
