Question about Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater
Installed when we installed our ceiling fans everything was ok now when we turn one on the other goes on in the up stairs apts
  • 4 Answers
The dip switches on the remote and on the fan have to match - which makes the remote and the fan on the same radio frequency so they can talk to each other. They all come with the same default setup of the dip switches (all in the "on" position and therefore they are all on the same radio frequency). That's fine unless there is a similar remote control fan nearby. So a remote might talk to several new fans if they are similar brand or same remote etc on the default dip switch settings and therefore same radio frequency. It's up to you to change the dip switches if you need to. You need to. They give you the ability to change the frequency so you don't control a similar fan down the hall, upstairs etc , while also controlling the one in the room that you intended to control ie your problem. As long as the remote and the fan match, they will talk to each other. So you have to change the dip switches on one of the remotes and the fan you are using that remote on to something different, but matching. There are usually four dip switches, usually all in the "on" position. So, for example, change the first dip switch to off on the remote and do the same to the fan - turn first dip switch off. You'll probably have to take the fan down and take off the top to get at the dip switches. That should fix the problem.
My fan: Hampton Bay 54 In. Brushed Steel with Remote Model 55295
Posted on Sep 17, 2008
How much should i charge for painting a two bedroom apt. Inteior only. walls and cealing two bath one living room kitchen and laundry room
About 50 cents a square foot would be a reasonable price for a straightforward paint job (no stairs, cathedral ceilings or furniture to move).
May 28, 2014 | Measuring Tools & Sensors
Model cd 52
Check your wiring connections and make sure everything is OK. Also check your capacitor and make sure everything is OK there too.
Aug 15, 2013 | Hunter 52" Ceiling Fan With Light And...
2003 gulf stream prairie schooner 5th wheel computer box/electrical problem
ac runs off 120 volts refrigerator 120 volts heater element 12 volt heater element and control board outside lights 12 volt ceiling fan 12 volts wires that go to box 2 blue furnace 12 volt wires from thermostat 12 volt
May 10, 2017 | RVs
I installed model 27303 ceiling fan with light. I had an electrician inspect the wiring to make sure everything was wired correctly, and it was. With the power on the fan/light operates with the remote...
Is it possible that there is another remote, either yours or a neighbor's, close enough to operate it?
I installed a remote operated ceiling fan & it is hard wired, there is no switch. If that happened to me, I'd be stuck never knowing when it will come on.
Can you change the remote code?
Aug 25, 2011 | Hunter Dryers
I moved into a place that has a MasterCool Evaporative Cooler on the roof. The ownstairs is quite comfortable so I really only need to cool the 2nd story.... it seems as if all the cold air settles...
jbrown - Hot air rises, Cold air falls. If you have ceiling fans upstairs, turn them on to run counterclockwise at highest speed you can stand. Make sure all the windows are closed upstairs. The ceiling fans will help to keep the cool air upstairs and pull some from downstairs.
If you don't have ceiling fans, invest in a box type fan that you can place at the head of the stairs (that's the top of the stairs) run it on HIGH and it will act like an exhaust fan, by pulling cool air upstairs. It may take a while, but it will help cool the upstairs to some degree.
Hope this helped you. Please let me know. Thanks.
Jun 24, 2011 | Mastercool 67471 Evaporative Cooler Air...
Hunter breeze low profile ceil fan, 5 blades 3 lights, Wobbly
Can you describe the mounting bracket for this fan?
If it is a ball mount, then there is a groove in the ball that connects to a tab in the mounting bracket. if the tab is gone or the ball is not sitting down in the bracket so that it is secure , then that is the problem. You may be able to find a replacement brachet in a home depot type store .
Please Vote !!
May 26, 2010 | Hunter 20436 Beacon Hill White Ceiling Fan
Can you please tell me how to install my Heritage ceiling fan?
Its really easy but you need to be safe, make sure all circuits are off to the outlets you are working on. Usually everything is color coated black goes with black (hot), white goes with white, ground goes with green or copper make sure you use electrical tape to tape up, then assemble from there using istructions. Hope this helps
Nov 17, 2008 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Redington IV Hampton Bay Ceiling fan lights don't work and we don't know where the receiver goes.
I have the same fan. You have wired it wrong. The receiver goes under the collar cover. It is a tight fit but it is the quietest fan I have.
Mar 17, 2008 | Dryers
I need to remove my hampton bay ceiling fan from the ceiling.
im trying to install light to ceiling fan but the wires are a different color and light wont come on
Jan 15, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater Logo
369 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
