Loss of picture on Television - only a sliver of the picture running horizontally remains
When tv is on - picture is only a sliver running horizontally. All sound and other items work. What do you think it is?
Thanks,
    Brigadier General:
  • 6,966 Answers
Hi paquetor,
Based on your post/description, I can only suspect a Vertical failure in your TV. This problem is pretty common and is relatively easy to repair. Often, this involves replacing the Vertical IC which is not that expensive. Basic knowledge of electronic circuitry and components, use of a soldering iron and an electronics part shop near you is all that is required. Of course standard safety precautions apply when working with HV such as in your TV.
There are instances that the coupling capacitor also goes bad. This is also normal after some time due to heat buildup. Being not that expensive (a couple of dollars), it may also be worth your while to similarly replace while the set is open. This capacitor would be relatively bigger than the others in the vertical circuit and is commonly located physically near the vertical IC.
Should you not be comfortable performing a do-it-yourself, perhaps you may need to seek the services of a qualified professional.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 08, 2008
21" sony tv horizontal amp short what is the
The most common cause of this symptom, by far, is the loss of vertical deflection amplifier. It usually requires the replacement of the vertical output transistor or some component associated with it. The cost of repair would run around $150 to $200 depending on the exact parts replacement and the shop that does the work.
i hope this will be help full to you .
goodluck
Feb 02, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Tv turns on then off
hold the menu and input buttons simultaneously for 5 seconds. the tv will blink an error code
Error Code Probable Cause
12 Normal Operation - No Error Detected
21 X-Ray Protect
22 Short Protect - likely convergence IC failure
23 Loss of Horizontal Deflection
24 Loss of Vertical Deflection
Fast Blink for 70 sec. After AC is applied = Normal - DM μPC is booting up
Fast Blink (doesn't stop) After AC is applied = TV μPC is running, but DM failed to boot up
Slow Blink Set is Off = Normal - Timer is set for Automatic Turn ON
Dec 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi VS 50707 ( not 705)
I have the same TV built in 99. My problem is similar but the vertical hold gives out when the tv warms up about 5 minutes. I will attempt to locate the vertical hold circuit and replace any parts I suspects may be the problem. I suspect a cap is leaking or transitor around IC700 is degrading when warm.
Jul 31, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Panasonic PT-51HX43G no picture
You have a loss of horizontal deflection. It is a possibility that you have burned that line down one or more of the CRT's. The repair wil take the help of an expert since the horizontal section puts out signals of 1200 volts or more.
Jun 09, 2008 | Televison & Video
Picture color
more then likely it could be your blue tube is bad.
Apr 27, 2008 | Sony KP-51HW40 51" Rear Projection...
1995 Mitsubishi 40" Television - Worth Repairing?
there are bad solder connections on the vertical deflection IC resolder them and you will be fine
Mar 13, 2008 | Mitsubishi CS-40503 TV
Dark Picture on my 5 year old 42H81
Any horizontal or sqiiggly lines in the picture or just a loss of light level?
Nov 07, 2007 | Toshiba 42H81 42" Rear Projection...
Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
Jan 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
TV picture problems
this modle has a bad solder connection near the horizontal o/p transistor that causes the picture to fade in & out.the bad solder connection is on a small coil. the coil winding is typically red. looking at the back of the tv, the flyback has the rid wire going to the top of the tube, the horizontal o/p transistor is to the left & in font of the flyback, it's attached to an aluminum heatsink. directly in font of this heatsink is the coiul you are looking for, it should have a location id of L14XXX or L4XXX if I remember corectly. good luck.
Dec 08, 2006 | RCA F27440 27" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
