    Brigadier General:
  • 6,966 Answers
If I understand your post right, you have the code but need the procedure on how to input/enter it into the radio. To my understanding, a 1995 Volkswagen Passat would have a non-BOSE unit with or without CD changer controls. It was a premium sound system with anti-theft coding.
Pls try:
1. Power the radio ON till "SAFE" is displayed;
2. Press the AM/FM and SCAN buttons simultaneously till display shows "1000". (In some versions, it is the seek and the two scan buttons);
3. Release the AM/FM and SCAN buttons;
4. Enter your security code using the first four station buttons on the radio;
5. The first button changes the first number of the four digit code;
6. The second button changes the second number and so on and so forth;
7. Once the proper code has been entered press the AM/FM and SCAN buttons at the same time and hold until the radio accepts the code;
8. You have two tries before the system will lock you out for an hour;
9. Should you happen to have a three digit code, pls make the first digit a zero;
10. The first digit can only be 1 or 0 (the 0 will not show up so for a zero, push the button until the 1 disappears).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 08, 2008
How do you enter the digits into radio on Volkswagen passat 2001model
got me here only ever seen a 4 digit ,try entering the first number with the first NO1 button then you press the am/fm button and it changes and the seconde one flashes then do the same with the NO1 button ,think it may be another button and not the am/fm one ,AFT or something ,just cannot remember as its not the sort of thing i do every day or better still ask in the dealers they will know their own models
Mar 29, 2012 | 2001 Volkswagen Passat
How to enter radio code for 1995 bmw525i (after replacing battery)
If you know the 5 digit code you can use the preset buttons for number entry - press the corresponding number on the preset buttons and you should hear a beep if successful.
If you don't know the code, your local BMW dealership can help by giving them the car's VIN number.
May 11, 2011 | BMW 525 Cars & Trucks
How do you use radio code for 1995 vw passat to get radio out of safe mode
You must have the security anti-theft code for your VW radio from the car manufacturer, or from a VW dealer!
You can find the radio code at:
The sequence of programming for 1995 VW Passat radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Mar 17, 2011 | 1995 Volkswagen Passat
How to exit Radio Safe mode on my passat
Wiih most radio units....If you have the proper code and have NOT tried more than 15 times to enter an incorrect should be ok.
Turn OFF ignition switch and remove the key. Switch OFF interior lights. Switch ON Radio unit and SAFE will appear.
Leave everything alone for a period of ONE HOUR. During this time NO power (no matter how small) should be drawn from the battery. This is why the interior lights MUST NOT come ON when the door is opened. Trunk should also remain closed. In the event of any power been drawn from the battery in this time...You must start all over again.
Radio should after this time return to standard mode...Usually 4 flashing bars. Then enter your code. Dont forget to lock in the code and all should be fine
All the best with it
Nov 26, 2009 | 1998 Volkswagen Passat
Need the radio code
well, I don't know, the dealer has all of that info, but if your lucky you can pull the old radio and maybe a previous owner or mechanic was thoughtful enough to write the code on top. Locate the two springloaded tabs on the left and right sides of the face, push them in gently with a knife or flat screwdriver and use them to pull the radio out. Good luck.
Jun 01, 2009 | 1995 Volvo 850
Radio Locked bc of Battery
normally have 2 press the rds button and the tps button at same time then enter code
May 20, 2009 | 2006 Volkswagen Passat
Vw passat radio code
Passat 97 need to re-enter code ( 4 ) digit, however it shows the number 2 on the on screen when the radio is turned on.
Help. I need to know the steps to reset. thanks
Dec 13, 2008 | 1999 Volkswagen Passat
I just raplace my radio in my VW passat 99 need to enter code
I left my radio on for one hour, then re enter the code (the one I was trying to enter was the wrong one). Radio is working well.
Nov 15, 2008 | 1999 Volkswagen Passat
Radio code
i need the radio code for my honda accord
Aug 27, 2008 | 1995 Honda Accord
296 people viewed this question
